tonylauno1 7 Report post Posted July 4, 2018 Has anyone gone for the bigger alloy at rear look? ie front 225/45/17 & Rear 225/40/18 Since the rear has much more "body" compared to front, same size alloy makes rear alloy look smaller. These days, some models have bigger rear wheels which make the car look more proportional from the side view, however their tyre sidewall seems to be about the same which means rear alloy with tyre will have bigger overall diameter. I'm sure everything is calibrated correctly by engineers. One thing I wonder is, if I go for Front 225/45/17 & Rear 225/40/18, the alloy will look more proportional but I don't know how the smaller rear tyre sidewall will look since I can't increase the sidewall height as I need to keep to the same overall diameter. Just can't imagine how rear with look with less tyre sidewall, will it look funny? I know if I used 225/45/18 then it will looks better since nothing has changed except for bigger alloy. Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted July 4, 2018 Why not just run a wider rear wheel? With a smaller aspect ratio on the rear the setup looks balanced. Quote Share this post Link to post Share on other sites
tonylauno1 7 Report post Posted July 4, 2018 11 hours ago, Herbmiester said: Why not just run a wider rear wheel? With a smaller aspect ratio on the rear the setup looks balanced. Can run wider rear tyres but it's the look from the side. Wider rear wheels are still the same 17" alloy, sidewall height are still the same. To eliminate the wider tyres from being the focus of this thread, let's say 225/45/17 & 255/35/18 Note that 225/45/17 & 255/40/17 OR 225/40/18 & 255/35/18 actually looks the same from the side, they only look different when you view it from the front or back. The point is the same alloy diameter on rear looks smaller since there's more metal above it, more "body". It's like asking an adult and a child to stand side by side and hold a can of Coke. The can of Coke will look smaller in front of the adult. Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted July 4, 2018 Ok so this is all about how something looks rather than how something performs? Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted July 4, 2018 my mind can only picture this.. 1 3 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted July 5, 2018 It would be interesting to see a pic of a bmw where someone has done this so we can visualize it. Quote Share this post Link to post Share on other sites
TLH 45 Report post Posted July 5, 2018 32 minutes ago, zero said: It would be interesting to see a pic of a bmw where someone has done this so we can visualize it. Had a quick look on google, not a bmw but still gets the point across I guess. Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted July 5, 2018 Hmmm, not my thing....... Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted July 5, 2018 There was a guy who ran double staggered Hartges on his e30. Can't for the life find it now but looked good Quote Share this post Link to post Share on other sites
tonylauno1 7 Report post Posted July 5, 2018 11 hours ago, Herbmiester said: Ok so this is all about how something looks rather than how something performs? Absolutely Sometimes I put 255 at rear, sometimes 245 depending on which is cheaper, it's been a while since I last had 225. It's oversteer too much, I'm more confident and can push more when it understeers. If I have really crappy tyre at front, I'm happy to put really good 225 tyre at rear. I do care about how it drives too but whether it's 255 or 225 at rear, I still want the aesthetics side of it Quote Share this post Link to post Share on other sites
tonylauno1 7 Report post Posted July 5, 2018 10 hours ago, qube said: my mind can only picture this.. LOL now I can't get that out of my mind. That never crossed my mind, haven't seen a tractor since I went to the field days 10 years ago. 1 Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted July 5, 2018 Michelin Pasture Sport 4S on those new John Deere’s I heard. Quote Share this post Link to post Share on other sites
tonylauno1 7 Report post Posted July 5, 2018 Would still be interesting to see it on a bmw e36, e39, e46 as the rear has visibly more "body" above wheel arch compared to front. That Mustang certainly gets the point across, rear wheel looks like 2-3 inches bigger than front and the amount of body directly above wheel arch is very similar so in this case, rear wheel looks much bigger than it needs. I'll be searching double staggered e30 on Google ? Quote Share this post Link to post Share on other sites
tonylauno1 7 Report post Posted July 5, 2018 8 minutes ago, qube said: Michelin Pasture Sport 4S on those new John Deere’s I heard. I have new 225 Michelin Pilot 4 (not S) on front and half worn 245 GY Eagle D5 on rear. In dry I can accelerate around roundabout and car with rotate, front grip is amazing. I'm sure it will oversteer if I step on it but I haven't tried. In wet, I can't accelerate too much around corners, get decent speed, front will not lose grip, I have spun when I was testing how much traction I have in wet with no car nor pedestrian in sight in large open space Quote Share this post Link to post Share on other sites
tonylauno1 7 Report post Posted July 5, 2018 8 hours ago, zero said: It would be interesting to see a pic of a bmw where someone has done this so we can visualize it. Actually a friend pointed out the answer, here's a pic F82 M4 GTS has 19"front & 20"rear 2 Quote Share this post Link to post Share on other sites
