tonton 3 Report post Posted August 18, 2018 hey guys, my e60 does exactly what is shown in this video the author of the video points it to corroded grounding cables for the engine, but some say its the starter. can anyone point me in the right direction? thanks! Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted August 19, 2018 yes have seen bad earth strap conections on e60 e64 etc , from where the steel chassis conects to the ali front rails etc , and the rear straps etc Quote Share this post Link to post Share on other sites
tonton 3 Report post Posted August 19, 2018 3 hours ago, BM WORLD said: yes have seen bad earth strap conections on e60 e64 etc , from where the steel chassis conects to the ali front rails etc , and the rear straps etc do you guys do earthing strap replacements? Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted August 19, 2018 I would suggest getting it checked properly before throwing money at it when you don't actually know whats causing the issue 1 Quote Share this post Link to post Share on other sites
tonton 3 Report post Posted August 19, 2018 2 hours ago, B.M.W Ltd said: I would suggest getting it checked properly before throwing money at it when you don't actually know whats causing the issue i've already scanned my car with a scanner, no error codes or anything. probably going to try directly earthing the engine with a jumper and see if it solves the slow crank issue. if not, then it's probably the starter going bad soon Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted August 19, 2018 Hardly a fault that is likely to throw a code. You are obviously guessing the fault by your diagnosis. As Glenn said - get it checked properly. Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted August 19, 2018 16 hours ago, tonton said: do you guys do earthing strap replacements? loosen earth strap bolts then retighten 1 1 Quote Share this post Link to post Share on other sites
Whatchain 5 Report post Posted August 21, 2018 My 335i did that exact same thing. I put it on the trickle charger overnight and it seems to have made it waaaaayyyyyy better. these battery needs a good charge once in awhile. Try that before doing anything else. connect charger to the engine bay point rather than battery Quote Share this post Link to post Share on other sites
tonton 3 Report post Posted August 21, 2018 12 hours ago, Whatchain said: My 335i did that exact same thing. I put it on the trickle charger overnight and it seems to have made it waaaaayyyyyy better. these battery needs a good charge once in awhile. Try that before doing anything else. connect charger to the engine bay point rather than battery ahhh i see. Will try that out! Theres also a possibility that my battery is already old. I've checked my earth straps and they look to be in fairly okay condition. Quote Share this post Link to post Share on other sites
Whatchain 5 Report post Posted August 24, 2018 either a good charge of new battery. the charge has fixed the slow crank for awhile but i was told by auto electrician it's doesnt bring it up to the charge level it should be (40 to 50%). in saying that my battery is over 5 years old so well overdue for a new one. expect about $270 for a new AGM battery. Quote Share this post Link to post Share on other sites
Herbmiester 946 Report post Posted August 27, 2018 On 8/20/2018 at 8:33 AM, BM WORLD said: loosen earth strap bolts then retighten Used to do that all the time when I was an apprentice auto sparky. Quote Share this post Link to post Share on other sites
