Deano1968 38 Report post Posted December 9, 2018 (edited) As the title says, looking for a 89.6mm stroke crank out of an S52B32 engine. Cheers. Edited December 9, 2018 by Deano1968 Quote Share this post Link to post Share on other sites
NZ00Z3 190 Report post Posted December 9, 2018 Have you tried the USA and Canada BMW sites? The S52 being very common in the USA Z3M's and E36M's will give you a wider net to get one. Quote Share this post Link to post Share on other sites
Deano1968 38 Report post Posted December 9, 2018 Hi Murray. No haven't tried overseas yet. Thought I'd try local first. Not that familiar with these engines or their availability. Any idea whether the S50B32 crank is the same, and if it is more likely to be more available in NZ? Cheers. Quote Share this post Link to post Share on other sites
Deano1968 38 Report post Posted December 9, 2018 Just done a little more research and it looks as if the M54B30 crank has the same stroke. Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted December 9, 2018 got a s54b32 crank if that helps Quote Share this post Link to post Share on other sites
Deano1968 38 Report post Posted December 10, 2018 OK, done some research and the S54B32 crank is not suitable. Looks like the M54B30 crank may be the easiest option. Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted December 10, 2018 56 minutes ago, Deano1968 said: OK, done some research and the S54B32 crank is not suitable. Looks like the M54B30 crank may be the easiest option. Out of curiosity which engine is it for? Quote Share this post Link to post Share on other sites
Deano1968 38 Report post Posted December 10, 2018 M20 Quote Share this post Link to post Share on other sites
Toast 120 Report post Posted December 10, 2018 9 hours ago, BM WORLD said: got a s54b32 crank if that helps price? 1 Quote Share this post Link to post Share on other sites
