Yungbuck 0 Report post Posted January 18, 2019 Recently bout a 318 gearbox to convert my 97 323i drift project to a manual I'm trying to find out which flywheel and clutch would fit? Any ideas? Quote Share this post Link to post Share on other sites
Blackie 510 Report post Posted February 12, 2019 Anything to suit an M52 should be good. There are M3 type kits on trademe for around 1,200 1 Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted February 12, 2019 Keep in mind that the shifter linkages are different between 4 and 6 cylinder cars 1 Quote Share this post Link to post Share on other sites
allan 295 Report post Posted February 12, 2019 If an auto check the cooling set up on the radiator they are different to a manual I believe. 1 Quote Share this post Link to post Share on other sites
Mad_Max 236 Report post Posted February 15, 2019 On 2/12/2019 at 8:37 PM, KwS said: Keep in mind that the shifter linkages are different between 4 and 6 cylinder cars Yep, 4cyl ones are longer. From memory, you can cut *I think* 32mm from the linkages and reweld back together to make them work if you're doing it on an extreme budget. It may be 35mm, it's around that though. On 2/13/2019 at 10:13 AM, allan said: If an auto check the cooling set up on the radiator they are different to a manual I believe. Na auto and manual are the same for the water hoses. Some of the older 36's had trans cooler lines go into the side of the radiator, others have a separate cooler at the front. Either way, you don't need to change the radiator, it won't leak if the trans lines aren't hooked up. 1 Quote Share this post Link to post Share on other sites
allan 295 Report post Posted February 15, 2019 Ah I see different set up from an e46 great makes life a little easier when doing the conversion best of luck and enjoy the 3 pedal experience. 1 Quote Share this post Link to post Share on other sites
