NZ_InFerno 397 Report post Posted February 23, 2019 I need a new rear driveshaft coupling for my new purchase, E87 130i. Looking to do it myself, so I’m ordering parts for it and want to check I’m getting the right bits, if there’s anything I need to be aware of in replacing the coupling and anything else I should do while I’m there. From Real OEM and the kits I’ve seen on fcpeuro I need 4 parts numbered 1,2,3/12 and 4 from here: www.realoem.com/bmw/enUS/showparts?id=UD52-EUR-10-2007-E87N-BMW-130i&diagId=26_0218 I’ve found these bits on fcpeuro which match the Realoem part numbers: https://www.fcpeuro.com/products/bmw-drive-shaft-flex-joint-giubo-meylehd-3141523102hd https://www.fcpeuro.com/products/bmw-drive-shaft-flex-joint-nut-26127536563 https://www.fcpeuro.com/products/bmw-hex-bolt-m10x5510zns3-26117551225 https://www.fcpeuro.com/products/bmw-drive-shaft-end-bushing-26117526611-1 So am I good to go or do I need anything else? Quote Share this post Link to post Share on other sites
Jacko 2265 Report post Posted February 24, 2019 Other than Lining up the arrow/triangle things to the appropriate flange, its a bolt in deal. Quote Share this post Link to post Share on other sites
NZ_InFerno 397 Report post Posted February 24, 2019 1 hour ago, Jacko said: Other than Lining up the arrow/triangle things to the appropriate flange, its a bolt in deal. I was wondering if I should pm you, I think you had done it on your 130i? Cheers for the info. I've got the right parts I hope. Quote Share this post Link to post Share on other sites
allan 295 Report post Posted February 24, 2019 before removing the old one just look at where things are as Dan mentioned aline the arrow/ triangles or mark yours before you take it apart. Sure their must be a DIY on u tube or google on it by now . Quote Share this post Link to post Share on other sites
HELLBM 1674 Report post Posted February 24, 2019 Here you go. https://www.newtis.info/tisv2/a/en/e87-130i-sha/repair-manuals/26-propeller-shaft/26-11-single-multiple-part-propeller-shaft/GdAZqXJ 1 Quote Share this post Link to post Share on other sites
NZ_InFerno 397 Report post Posted February 25, 2019 This is all awesome info cheers @Jacko @allan and @HELLBM Quote Share this post Link to post Share on other sites
NZ_InFerno 397 Report post Posted February 26, 2019 I'm going to order these bits assuming they're correct ? Quote Share this post Link to post Share on other sites
