Kodachrome 164 Report post Posted October 21, 2019 Looking for good condition calipers, rotors etc from the newer bigger BMW's for my e28. Can buy online/abroad but thought to ask here first. 1 Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted October 21, 2019 have some spare 540i front discs Quote Share this post Link to post Share on other sites
Kodachrome 164 Report post Posted October 21, 2019 4 hours ago, BM WORLD said: have some spare 540i front discs The calipers are harder to find, but PM me a discs price anyhow! Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted October 21, 2019 $80-100 a pair Quote Share this post Link to post Share on other sites
Kodachrome 164 Report post Posted October 21, 2019 New or used? Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted October 21, 2019 13 minutes ago, Kodachrome said: New or used? like new /used ones Quote Share this post Link to post Share on other sites
Mad_Max 233 Report post Posted October 21, 2019 If you don't need them desperate urgently (only cause pouring rain down here) I may be able to get calipers and all the mounting hardware off an E39 540i (possibly rears, might just be fronts, have to check), or everything (front and rear) off an E38 740i - all will be second hand if that's any use? Quote Share this post Link to post Share on other sites
Kodachrome 164 Report post Posted October 22, 2019 5 hours ago, Mad_Max said: If you don't need them desperate urgently (only cause pouring rain down here) I may be able to get calipers and all the mounting hardware off an E39 540i (possibly rears, might just be fronts, have to check), or everything (front and rear) off an E38 740i - all will be second hand if that's any use? Thanks for the offer, but sadly E39 and E38 brake parts wont fit an E28! Quote Share this post Link to post Share on other sites
User Name 19 Report post Posted October 22, 2019 (edited) Hi Guys/Gals, For your view pleasure, hope this file helps I would have to check the shed but pretty sure i have a set of 540i rears and E32 Fronts (complete or other way around its been a while) if i remember correctly it was the largest OEM i could fit under 15's without upgrading to porche or big brake kit (10 years ago) on my E28. I am probably just going to go with non oem brake upgrade next time round as my performance is past the stock brakes or maybe see if my 750il ones fit PM me if needed E28 Brake upgrade.rtf Edited October 22, 2019 by User Name Update 1 Quote Share this post Link to post Share on other sites
Mad_Max 233 Report post Posted October 22, 2019 11 minutes ago, User Name said: Hi Guys/Gals, For your view pleasure, hope this file helps sh*t there's some great info in there, quite a bit to read and absorb. Gives a wide variety of options...... interesting....... Quote Share this post Link to post Share on other sites
topcat 11 Report post Posted October 22, 2019 2 hours ago, Kodachrome said: Thanks for the offer, but sadly E39 and E38 brake parts wont fit an E28! I had adapter brackets made to connect the e38 factory brembo brake option to fit e28's. rotor is hugh though, from a e60 550 from memory stopping power was/is quite eye opening. can't fit all 17" wheels, but will fit all 18's Quote Share this post Link to post Share on other sites
Kodachrome 164 Report post Posted October 22, 2019 31 minutes ago, topcat said: I had adapter brackets made to connect the e38 factory brembo brake option to fit e28's. rotor is hugh though, from a e60 550 from memory stopping power was/is quite eye opening. can't fit all 17" wheels, but will fit all 18's That actually pretty cool, did you change the Master Cylinder for the brakes too? I have to stick to what fits under 16" E32 wheels though! Quote Share this post Link to post Share on other sites
topcat 11 Report post Posted January 7, 2020 hi, just saw this reply in . fitted a e32, 750/ 25mm unit. if i were to do it again.... there will always be a next time.... i would fit pedals and remotes setup, that way would be able to increase the pressure/shorten the stroke Quote Share this post Link to post Share on other sites
