Herbmiester 947 Report post Posted June 10, 2020 Quote Share this post Link to post Share on other sites
gjm 3292 Report post Posted June 10, 2020 Certainly gets around one of the questions I often find myself asking when I work on a car that's new to me. Finding a sensible place for jacking, and a sensible place for a stand. Claimed to be safer than 'normal' stands. And the RS3 version is good for 3 tons, and larger jacks. Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted June 10, 2020 Great idea. Just poorly executed - I would want alot more strength Quote Share this post Link to post Share on other sites
NZ00Z3 190 Report post Posted June 10, 2020 All depends on how low the car sills are and the low profile of your jack. Would need a low profile jack for a Z3. Wouldn't work for a Z4, sills just too low. Quote Share this post Link to post Share on other sites
gjm 3292 Report post Posted June 10, 2020 5 hours ago, zero said: Great idea. Just poorly executed - I would want alot more strength My thought too - looked a bit... not exactly flimsy, but not as robust as I'd like to see. 47 minutes ago, NZ00Z3 said: All depends on how low the car sills are and the low profile of your jack. Would need a low profile jack for a Z3. Wouldn't work for a Z4, sills just too low. Aye. Adds an inch or so to the jack pad height. Possibly not a problem for many cars, but anything low(ish) is going to require a different approach. Drive up on to blocks first, perhaps? I have pieces of 25-40mm thick wood, 300mm square, that I use. I do like the idea of being able to use the jacking point for the stand. Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted June 23, 2020 My e92 is low so I bought a low profile jack and I think its the way to go. Pretty confident I could get this under the car between the jack and lifting point, possibly not if you had a normal height jack. Not sure I agree with flimsy, looking at my traditional jacks it has a wider base so probably better in respect to stability. All that said being able to jack at the lift point is a huge plus. I will look to get some and see how they work in the real world. Quote Share this post Link to post Share on other sites
