MattS NZ
Matt NZ
Hi team
I have a 2005 e46 m3, import from the UK. Recently purchased an Avin Avant 4 stereo to upgrade from what I understand is the factory stereo. I started following the instructions but the connectors at the back were not as expected. Does anyone know what these are (in the photos) and how to connect the new stereo?
Really appreciate the help!
Matt
New Avin stereo: https://avinusa.com/avant-4-multimedia-navigation-system-for-bmw-3-series-e46-m3.html
call me
021433600
Hi Matt,
you should have ordered the extension cable..
the blue and white plugs are connectors to the audio system located in the boot.
Pretty sure the factory bluetooth module for an E46 (if fitted, which is again in the boot) has a connector like those.
It’s similar as in quadlock pin system but connector is larger and terminates with the boot.
Dogballs post is on the money.
