M3AN 4195 Report post Posted October 10, 2020 So, like many of us I imagine, I have no idea what brake fluid is in my imported car (130). I'm assuming it's standard Dot 4. I want to do do a flush/replace, I realise I can't used Dot 5 if the car already has Dot 3 or 4 but I understand Dot 5.1 is fine because it's backwards compatible with everything. Given it's beneficial properties, even if I don't need them, is conventional wisdom to got with 5.1? Is cost the only disadvantage? $100 for a full flush every 5+ years doesn't concern me. Quote Share this post Link to post Share on other sites
Jacko 2371 Report post Posted October 10, 2020 (edited) I run Castrol React Performance DOT 4, Which is essentially the same performance as DOT 5.1 ( and much higher than average DOT4 at 180/260c ), totally happy in BMWs and cheap as chups https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/B0F5626B0EB98D0B8025843C00213662/$File/BPXE-9VCL2X.pdf Edited October 10, 2020 by Jacko 1 Quote Share this post Link to post Share on other sites
M3AN 4195 Report post Posted October 10, 2020 Yep, that's what I run in the M3 and no complaints... I wonder if the anti-hydroscopic properties of 5.1 are worth the cost? Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted October 10, 2020 Used to use the Castrol but its get real expensive if you do a few cars or didnt quite have enough. Penrite superdot has similar specs iirc and is far better value in the 4.4L bottle esp when on special. 1 Quote Share this post Link to post Share on other sites
HalfJobHarry 106 Report post Posted October 11, 2020 If you keep up with the complete fluid replace every few years then any hydroscopic properties are likely not worth it. Interestingly BMW often specify the DOT 4 Low Viscosity fluid...which when I went to the dealer for it they initially told me "they don't sell it"...then when I produced a BMW part number they they were surprised saying "nobody never bought that before" Apparently there is "need" to run the LV fluid with BMW ABS/Traction Control ...but frankly I'm certain garages the world over have been putting in regular DOT 4 forever without ill effect. 1 Quote Share this post Link to post Share on other sites
