Herbmiester 947 Report post Posted April 6, 2021 My X5 40D keeps bring up a check engine light and the codes are: 49A6 Glow Plug Controller. New GP controller. 4CAE EGR controller position sensor. 40D4 EGR controller Position Sensor. 4C9F Exhaust-gas recirculation valve, plausibility 4C9E Exhaust-gas recirculation valve, plausibility 40B4 EGR Valve position control. Apart from the first one everything else is EGR related. I removed the EGR valve (10 min job) and it wasn't sticking, a small amount of carbon but less than I imagined. My question is do these fail otherwise? Is there a way of checking them, specifically the operation of the stepper motor? Quote Share this post Link to post Share on other sites
promo 93 Report post Posted April 6, 2021 i can do a EGR delete for you in the ecu. you can just leave the old one in and get blanking plate late. better for the engine after a delete 1 Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted April 6, 2021 (edited) 21 minutes ago, promo said: i can do a EGR delete for you in the ecu. you can just leave the old one in and get blanking plate late. better for the engine after a delete I am thinking that might be the way to go. Edited April 6, 2021 by Herbmiester Quote Share this post Link to post Share on other sites
balancerider 830 Report post Posted April 6, 2021 If the labour govt keeps doing things, I wouldn’t rule out emissions testing on WOF. I feel a bit uneasy about deliberately bypassing emissions tech too...YMMV obviously Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted April 6, 2021 3 minutes ago, balancerider said: If the labour govt keeps doing things, I wouldn’t rule out emissions testing on WOF. I feel a bit uneasy about deliberately bypassing emissions tech too...YMMV obviously Yes I understand your position I dont care so much about the legality more about the environment. Quote Share this post Link to post Share on other sites
NZE90 9 Report post Posted April 12, 2021 On 4/6/2021 at 9:18 PM, Herbmiester said: Yes I understand your position I dont care so much about the legality more about the environment. Do you know if your car has had the EGR cooler/valve recall done on it? If it hasn't it might be worth checking if it's due as they'll replace it for free. If it has had it done they may have not done properly hence the codes. 1 Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted April 12, 2021 1 hour ago, F30N20 said: Do you know if your car has had the EGR cooler/valve recall done on it? If it hasn't it might be worth checking if it's due as they'll replace it for free. If it has had it done they may have not done properly hence the codes. I will check. Quote Share this post Link to post Share on other sites
balancerider 830 Report post Posted April 12, 2021 2 hours ago, F30N20 said: Do you know if your car has had the EGR cooler/valve recall done on it? If it hasn't it might be worth checking if it's due as they'll replace it for free. If it has had it done they may have not done properly hence the codes. They only replace the cooler. Valve itself not involved with recall 1 Quote Share this post Link to post Share on other sites
NZE90 9 Report post Posted April 12, 2021 35 minutes ago, balancerider said: They only replace the cooler. Valve itself not involved with recall No they don't. BMW NZ directed all dealers to replace the complete EGR module which includes the EGR valve and cooler. 1 1 Quote Share this post Link to post Share on other sites
balancerider 830 Report post Posted April 12, 2021 Interesting, no mention of valve replacement on my recall invoice 1 Quote Share this post Link to post Share on other sites
NZE90 9 Report post Posted April 12, 2021 5 minutes ago, balancerider said: Interesting, no mention of valve replacement on my recall invoice Yes correct, they don't mention it. They were having too many problems with the EGR valves faulting after the EGR cooler had been replaced so they directed all dealers to replace the complete EGR module. 2 Quote Share this post Link to post Share on other sites
40dx5 0 Report post Posted November 11, 2021 On 4/6/2021 at 7:55 AM, Herbmiester said: My X5 40D keeps bring up a check engine light and the codes are: 49A6 Glow Plug Controller. New GP controller. 4CAE EGR controller position sensor. 40D4 EGR controller Position Sensor. 4C9F Exhaust-gas recirculation valve, plausibility 4C9E Exhaust-gas recirculation valve, plausibility 40B4 EGR Valve position control. Apart from the first one everything else is EGR related. I removed the EGR valve (10 min job) and it wasn't sticking, a small amount of carbon but less than I imagined. My question is do these fail otherwise? Is there a way of checking them, specifically the operation of the stepper motor? Hi, having very similar issues on my 40D. I changed the egr and reset the adaptations but still no change. Did you get this sorted in the end? Quote Share this post Link to post Share on other sites
The Bimmer 12 Report post Posted November 12, 2021 I have spare EGR Valve. Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted November 14, 2021 On 11/12/2021 at 5:12 PM, The Bimmer said: I have spare EGR Valve. Thanks, I have replaced the EGR and it runs a lot better now. except for oil in the intake which is either a turbo seal or bad PCV. Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted November 14, 2021 On 11/11/2021 at 10:38 PM, 40dx5 said: Hi, having very similar issues on my 40D. I changed the egr and reset the adaptations but still no change. Did you get this sorted in the end? A bit long winded but it looks like I have 2 issues . Faulty PCV valve and a faulty Glow plug controller. My auto sparky thinks the GP controller might be affecting other things but cant be sure. The stuffed PCV is the real issue. I have found a solution and will post up soon. Quote Share this post Link to post Share on other sites
santa 3 Report post Posted October 8, 2022 How did you get on with the PCV valve? Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted October 25, 2022 I replaced the PCV valve, it can be bought as a separate part from the rocker cover. I still have issues and Pramod will soon delete the whole EGR system in software and I will fit an EGR delete. Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted November 26, 2022 (edited) Well after a year I am back and I still have EGR codes and have decided to remove the EGR and get Prmod to code it out. Inspecting the engine today I noticed that there is moisture and some corrosion around the injectors. Any thoughts? Edited November 26, 2022 by Herbmiester Quote Share this post Link to post Share on other sites
F10er 66 Report post Posted November 26, 2022 (edited) The most common cause of this is cracked engine bay partitions. They start cracking and falling apart from the heat. Are yours intact? Edited November 26, 2022 by F10er 2 Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted November 27, 2022 11 hours ago, F10er said: The most common cause of this is cracked engine bay partitions. They start cracking and falling apart from the heat. Are yours intact? Yes mine were cracked and the mechanic put some sealant around them, it looks like that was not 100% successful. I will have to revisit this and possibly get the Silicone out. Quote Share this post Link to post Share on other sites
