Cammsport 391 Report post Posted January 10, 2022 Hi all. Battling through the 'resto' of my E39 touring. Doing the usual M52 maintenance as well. I noticed the radiator is the built-in-expansion-tank type that I'd only ever seen on 318tis'. I've seen other 6 cylinder E39s with the separate expansion tank that mounts to the shroud. My question is, is one better than the other? The built-in version is the same height and thickness but is 520mm wide vs 650mm. I can't seem to find much talk of it in the forums. I'll be replacing all of the cooling components bar the radiator if there's no gain from swapping. Thanks everyone! Quote Share this post Link to post Share on other sites
Eagle 1778 Report post Posted January 10, 2022 Both have their positives and negatives but prefer the older style myself purely from ease of working on\access point of view. I wouldn't think you could use the newer setup without fiddling around with the wiring\plugs and coolant lines given the M52TU\M54 is different from your M52 1 Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted January 12, 2022 Not sure which ones but alot of 328s have the top set up, mine does. I think it's a nz new vs Japan but not sure 1 Quote Share this post Link to post Share on other sites
Cammsport 391 Report post Posted January 26, 2022 On 1/12/2022 at 7:58 PM, Gaz said: Not sure which ones but alot of 328s have the top set up, mine does. I think it's a nz new vs Japan but not sure Awesome, cheers for that. Ever had any issues? Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted January 26, 2022 12 hours ago, Cammsport said: Awesome, cheers for that. Ever had any issues? No apart from it is leaking at the moment, am going to a m3 self bleeding setup for no other reason than preparing for future mods Quote Share this post Link to post Share on other sites
Palazzo 531 Report post Posted January 26, 2022 (edited) I have the same (top one) in my coupe. Just started seeping out of the bottom of the expansion tank. Looks like there is a washer or two able to be replaced? Edited January 26, 2022 by Palazzo Auto correct… Quote Share this post Link to post Share on other sites
