NZ_InFerno 397 Report post Posted October 14, 2022 Anyone know if this is available, or someone who does it in the Wellington region? I've done my headlights previously with a kit and they've yellowed again, was thinking of taking them to a pro but the plastic is in rough shape and probably would be better off getting a new lens put on if that's possible. Quote Share this post Link to post Share on other sites
M3AN 4199 Report post Posted October 14, 2022 For the 130? Assuming so then there's no ex-BMW lens kit although there might be some Taiwanese aftermarket kits but I'd consider that unlikely due to the nature of the assembly. They're pretty thick plastic, you can sand them back a fair way, the key is then to lacquer them with UV resistant clear and they'll stay perfect for pretty-much ever. That's a two stage process though, sanded professionally (and NOT UV coated), then take them to a paint shop for (I think) 2 pack lacquer. You can probably do both stages yourself but I'm not that brave. 1 Quote Share this post Link to post Share on other sites
NZ_InFerno 397 Report post Posted October 14, 2022 50 minutes ago, M3AN said: For the 130? Assuming so then there's no ex-BMW lens kit although there might be some Taiwanese aftermarket kits but I'd consider that unlikely due to the nature of the assembly. They're pretty thick plastic, you can sand them back a fair way, the key is then to lacquer them with UV resistant clear and they'll stay perfect for pretty-much ever. That's a two stage process though, sanded professionally (and NOT UV coated), then take them to a paint shop for (I think) 2 pack lacquer. You can probably do both stages yourself but I'm not that brave. Yep for the 130. I've seen the lenses online and had read about them being replaced. I was going to do that myself, I have another kit with multiple levels of sandpaper here atm and then was going to buy some 2k clear. But the lens is pitted inside so figure a new lens would get the best finish. I've got a voucher for a pro place that can do the headlights, so I might just take it there and see how it turns out if they can take a fair bit of sanding. Quote Share this post Link to post Share on other sites
M3AN 4199 Report post Posted October 14, 2022 Interesting, any thoughts on how or why they're pitted on the inside? I might be dumb on this one but I assumed any physical damage would be constrained to the exterior surface. Quote Share this post Link to post Share on other sites
NZ_InFerno 397 Report post Posted October 14, 2022 1 minute ago, M3AN said: Interesting, any thoughts on how or why they're pitted on the inside? I might be dumb on this one but I assumed any physical damage would be constrained to the exterior surface. It's got replacement halogen bulbs inside which aren't stock, my guess is they're giving off a bit of heat and over time have slightly distorted/damaged the inside of the lens. Or something else has got in and caused some corrosive damage, but that seems unlikely. 1 Quote Share this post Link to post Share on other sites
M3AN 4199 Report post Posted October 14, 2022 Interesting. If you end up going with aftermarket lens replacements please do post details of your experience, if it's good it would be worth hearing about. 1 Quote Share this post Link to post Share on other sites
Neil McCauley 483 Report post Posted October 14, 2022 1 hour ago, M3AN said: Interesting, any thoughts on how or why they're pitted on the inside? I might be dumb on this one but I assumed any physical damage would be constrained to the exterior surface. Not sure of @NZ_InFerno's exact experience, but I've been through a few E90's over the years, and the Xenon's are notorious for burning a ring on the inside of the plastic, had an F11 that did the same as well. It's obviously not pitting, but it looks really pitted when you look at the headlight from side on. 2 Quote Share this post Link to post Share on other sites
Driftit 2251 Report post Posted October 15, 2022 20 hours ago, Neil McCauley said: Not sure of @NZ_InFerno's exact experience, but I've been through a few E90's over the years, and the Xenon's are notorious for burning a ring on the inside of the plastic, had an F11 that did the same as well. It's obviously not pitting, but it looks really pitted when you look at the headlight from side on. I think my E87 has done this. I have an obvious ring even after I polished the outsides. Quote Share this post Link to post Share on other sites
NZ_InFerno 397 Report post Posted October 15, 2022 Yeah I have a weird ring effect as well. I'm not brave enough to do a home lens replacement haha Quote Share this post Link to post Share on other sites
