nath 184 Report post Posted October 22, 2022 Hi guys i have purchased a full 420g m3 evo conversion for my E36 Alpina B3 3.2 switchtronic. Provided I follow through with it some time- will there be issues with programming the ECU, considering it isn't a bog standard ECU or a common one? I will have a professional undertake the work. cheers nath Quote Share this post Link to post Share on other sites
Eagle 1788 Report post Posted October 23, 2022 Wouldn't think so as they would surely use the same MS41 DME as BMW (with custom mapping obviously) 1 Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted October 23, 2022 The standard e36 have a rev hang issue which bothers some people mote than others. Would imagine something similar possibly? Quote Share this post Link to post Share on other sites
nath 184 Report post Posted October 23, 2022 33 minutes ago, Gaz said: The standard e36 have a rev hang issue which bothers some people mote than others. Would imagine something similar possibly? Thanks- this is the kind of thing I won't put up with, it has to be 100% or nothing. Quote Share this post Link to post Share on other sites
KwS 2451 Report post Posted October 23, 2022 1 hour ago, Gaz said: The standard e36 have a rev hang issue which bothers some people mote than others. Would imagine something similar possibly? Mine had that after converting it, even with a light flywheel. Was a real PITA. Quote Share this post Link to post Share on other sites
Eagle 1788 Report post Posted October 23, 2022 1 hour ago, nath said: Thanks- this is the kind of thing I won't put up with, it has to be 100% or nothing. That comes down to the experience\skill of the person doing that side of the conversion. From my understanding rev hang can be eliminated by changing deceleration ignition timing values. I don't why MS41 seems to have an issue over the later MS43, they seem to operate the same auto\manual switch over when coding, clearing adaptions and aligning EWS, maybe some conversions arent doing this? Quote Share this post Link to post Share on other sites
