elias 460 Report post Posted January 7, 2023 Wheres the best place in auckland to go to get some AN lines made for a custom oil cooler setup. The parts are easy enough to source from racleab, NZKW etc but not sure how/where to get the hoses made, i.e fitting attached etc. Any advice appreciated, cheers Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted January 7, 2023 Enzed? Quote Share this post Link to post Share on other sites
Twistee 502 Report post Posted January 7, 2023 Yes Enzed can supply a complete custom hose solution for you. Quote Share this post Link to post Share on other sites
Cement 913 Report post Posted January 7, 2023 I've put a small mortgage through Racelab for Speedflow fittings ... pretty sure they can make the hoses up for you there also. Same as GSS and other places. Pop in and see Neil for a chat Don't be put off assembling yourself also its all pretty straight forward 👍 1 Quote Share this post Link to post Share on other sites
Twistee 502 Report post Posted January 7, 2023 If you want a crimped fit commercial hose then Enzed is your way, if you want a braided set up then follow Cements advice. If you do go through DIY then buy all the gear from one brand, AN hosing is not all the same and won't always play well between brands. 3 Quote Share this post Link to post Share on other sites
elias 460 Report post Posted January 7, 2023 sweet, cheers for the replies and recommendations! Quote Share this post Link to post Share on other sites
