modz 156 Report post Posted November 9, 2024 1x available, no outer tie rods. Available for pickup in Auckland after 16th Nov. Pm me if you’re keen. 1 Quote Share this post Link to post Share on other sites
topnotchrally 170 Report post Posted November 18, 2024 What car is this from? Will it fit a Z3 2.8? Thanks. Quote Share this post Link to post Share on other sites
modz 156 Report post Posted November 18, 2024 It would as the Z3 is based on an E36 chassis and the purple tags are from E36/E46 chassis, BUT the Z3 should be a blue tag in which case there's not much benefit for you. Quote Share this post Link to post Share on other sites
topnotchrally 170 Report post Posted November 18, 2024 25 minutes ago, modz said: It would as the Z3 is based on an E36 chassis and the purple tags are from E36/E46 chassis, BUT the Z3 should be a blue tag in which case there's not much benefit for you. Yes, thank you for your observation. I am only thinking of changing because my local WOF shop is, I believe, overly zealous and have said my rack may fail soon because of 'end play'. This seems crazy to me as it only has 135k kms on it. This is a bit off topic, but is this 'end play' a known issue? My 318i has >250k kms and it passes fine. Quote Share this post Link to post Share on other sites
modz 156 Report post Posted November 18, 2024 Seems rather OTT. I've had 300km+ cars with no rack change. There's not much inside the racks so it could actually be your inner tie rod rather than the rack itself. Quote Share this post Link to post Share on other sites
jom 98 Report post Posted November 18, 2024 My rack (at 240k) failed the wof on play in the rack - seems to be a new thing. The teeth in the centre of the rack get worn and cause the play. I went through 3 secondhand racks - all worse than mine - before I found one with less wear. Now I've got a purple tag rack, which apart from being a bit quicker, is proportional rather than being slower around straight ahead. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2152 Report post Posted November 28, 2024 i have put three e46 through wof recently, all three with advisories only on steering racks. plenty of e30s etc as well. They just arent as tight as modern cars, and the new wof techs that dont know the old stuff dont know . Quote Share this post Link to post Share on other sites
topnotchrally 170 Report post Posted November 28, 2024 1 hour ago, _ethrty-Andy_ said: i have put three e46 through wof recently, all three with advisories only on steering racks. plenty of e30s etc as well. They just arent as tight as modern cars, and the new wof techs that dont know the old stuff dont know . This is a good point, but how do you convince them it doesn't need changing? Quote Share this post Link to post Share on other sites
