denpin 5 Report post Posted November 15, 2024 Hi, I have sanded both headlights, starting with 400 grit and working my way up to 3000 grit, using a rotary sander. The results are uneven with fogginess along the lower part of the headlight? What could be the reason for this and could you recommend a possible fix? Many thanks. Quote Share this post Link to post Share on other sites
mmario 67 Report post Posted November 17, 2024 Boy that looks bad, I think you probably need new lights to fix that. Not sure a rotary sander is the best idea just go by hand Quote Share this post Link to post Share on other sites
Danch 43 Report post Posted November 17, 2024 Don't you need to polish it and add some UV coating? Quote Share this post Link to post Share on other sites
Cement 913 Report post Posted November 18, 2024 Looks like you just need to keep going !! Possibly previous clear coat on one part and not the other giving different hardness ? Quote Share this post Link to post Share on other sites
aja540i 1922 Report post Posted November 18, 2024 I suspect you have sanded through the outer layer which is probably a scratch / UV resistant layer, you can polish it up fine from there just make sure you coat it with something to protect it from UV once you are done. Quote Share this post Link to post Share on other sites
denpin 5 Report post Posted November 18, 2024 Thanks for all the feedback. I will polish the headlights over the weekend and post the results. Quote Share this post Link to post Share on other sites
denpin 5 Report post Posted November 24, 2024 I polished the headights using a fine compound on an orange foam pad, and the problem is now fixed! 4 Quote Share this post Link to post Share on other sites
