BMWALEX478 0 Report post Posted January 15 (edited) Hi everyone, I am completely new to this forum and new to owning a car let alone a BMW. I have no experience with cars. I have recently bought a 2007 BMW 130i which has done 106,000km with the N52 engine. When I start the car, I sometimes smell a burning smell and the idle is quite rough for a bit. There is also white smoke coming out of the driver side (RHD) of the engine which I have read is usually caused by a bad valve cover gasket. However I think I might also have an oil filter housing gasket leak too and it seems pretty oily around that area. I've heard this can be catastrophic as it can derail the serpentine belt but the belt looks dry to me. I will add some photos. Am I right to think that the rough idle could be caused by oil getting into the spark plugs from the leaky valve cover gasket? Also is it safe to drive my car? Thank you all. IMG_2738.heic IMG_2740.heic IMG_2741.heic IMG_2742.heic Edited January 15 by BMWALEX478 Quote Share this post Link to post Share on other sites
Jacko 2283 Report post Posted January 15 Yeah thats leaking bad and has been for awhile, new gaskets and a good clean up. I wouldnt be surprised if the spark plugs/coils are swimming. If you pull a coil pack you'll be able to tell fast. Quote Share this post Link to post Share on other sites
BMWALEX478 0 Report post Posted January 15 Thanks for the reply, which gaskets need replacing? the ones I mentioned? Also what do you mean by 'if you pull a coil pack you'll be able to tell fast' sorry for my lack of knowledge. Do you think that the spark plugs and coils would have to be replaced if they are covered in oil? Thank you. Quote Share this post Link to post Share on other sites
Jacko 2283 Report post Posted January 15 Valve cover gasket, oil filter housing gaskets, and the sumps probably leaking as well. They all leak, if they are not leaking, they will soon Great engines otherwise. Take the plastic cover off the top of engine, it pulls off. Lift the latch on the connector for a coil, pull a coil out. If its dripping in oil, your valve cover is leaking not just on the outside (and onto the exhaust) but onto the plugs. It depends on how long its been leaking for if the coils require replacement. Quote Share this post Link to post Share on other sites
BMWALEX478 0 Report post Posted January 15 Thanks, I will do that. Where would you recommend me to go get this done and what sort of money would you expect them to charge for each job? I am south east Auckland. Quote Share this post Link to post Share on other sites
Driftit 2222 Report post Posted January 15 Welcome. Make yourself a coffee and sit and read the 130i post for a few hours/days. Ton of info in there about the problems we have all had with our 130's. Tons of upgrade info too. Once you sort your oil leeks (I still have oil leeks on both of mine) look at upgrading the coolant connections to the engine block. Easy job. Keep asking questions. 1000's of hours of working on these cars between us all. 1 Quote Share this post Link to post Share on other sites
BMWALEX478 0 Report post Posted January 15 Thank you. Do you have a rough estimate on much it might cost to get my oil filter housing gasket and valve cover gasket replaced? I don't think I should try myself because I have no tools unless its a very easy job? Quote Share this post Link to post Share on other sites
Jacko 2283 Report post Posted January 15 (edited) Cant comment on costs as Im a DIY guy Parts are not particularly expensive though. Labour for the rocker and oil filter housing will be a few hours, the sump will be significantly more as subframe requires dropping. Id definitely recommend https://www.pandsauto.co.nz/ who should be local to you, and are one the of the few workshops where I have had work done that wasnt sh*t. Edited January 15 by Jacko Quote Share this post Link to post Share on other sites
Driftit 2222 Report post Posted January 16 Agree. I raced with Peter and Graham from P&S. They know their stuff and look after at least a good third of the entire BMW race series cars. Quote Share this post Link to post Share on other sites
Danch 43 Report post Posted January 16 Oil filter housing gasket job costed me about 450ish. I heard it's easy to DIY though. Quote Share this post Link to post Share on other sites
Harper 609 Report post Posted January 16 3 hours ago, Driftit said: Agree. I raced with Peter and Graham from P&S. They know their stuff and look after at least a good third of the entire BMW race series cars. Diy kinda guy myself as well but they're just around the corner from my work and they always have nice stuff parked outside. Minty E24 M6 a month or so back. Quote Share this post Link to post Share on other sites
