Silver Fox 43 Report post Posted June 15, 2006 Hi, bought an E30 318i with a cracked head, have fitted a new motor, and it's going, but I can't get any drive or reverse now, the new motor went in OK, is there something silly I might have done somewhere? Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted June 15, 2006 does the car roll? as in when you take it out of park? if so your your trans is gone. Check the connection of the gear selector. esp the one on the gearbox. Quote Share this post Link to post Share on other sites
topless 14 Report post Posted June 15, 2006 Is there oil in the gearbox? <--- silly but you never know!! Also silly.... did you replace the 3 bolts that secure the torque converter to the flex plate?? Apart from that I go with the linkage having fallen off.. If all else fails, go have a :beer: Will Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted June 15, 2006 Thanks, tranny fluid is to top of dipstick, replaced the 3 torque conv bolts, linkage seems fine, I'm having that beer, Cheers. Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted June 15, 2006 the fliters may need replacing. blocked fliters dont make the car go anywhere. i have had it happen to me. driving along then, stop. park up. call AA then towie. Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted June 15, 2006 i have a good auto from a 1990 318i done 96k . 021433600 ah . $500 Quote Share this post Link to post Share on other sites
danutt 4 Report post Posted June 15, 2006 take the offer above...good deal dont mess around if theres no gears like wat happened to mine i had it diagnosed as no forward clutches i had reverse tho so i did a gearbox swap and all good when you do swap myt as well go manual i regret replacing the auto box as im actually saving now to do a manual swap when this box blows just make it manual wish id have taken these guys advise on that but i desperately needed it back on the road for work so yea borrow a car or use another and do a manual swap cheers Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted June 17, 2006 If my torque converter was dry or stuffed, would that stop me getting any drive in foward and reverse? Thanks. Quote Share this post Link to post Share on other sites
cruznz 0 Report post Posted June 18, 2006 was it,[t/c] off at all? if so,did it go on properly,possible pump damage if not Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted June 18, 2006 Yeah, it was off, but went back on fine, and all bolted back to the ring gear plate, but have no drive. Quote Share this post Link to post Share on other sites
cruznz 0 Report post Posted June 18, 2006 well if fluid levels ok,selector linkages are fine, checks to valve body and pressure regulator and fluid pressures will be needed. Maybe double check everything , fluid lines, selector, etc, assuming it was drivable before engine swap? Quote Share this post Link to post Share on other sites
danutt 4 Report post Posted June 19, 2006 NEW BOX which is why i say dont replace or repair just go MANUAL thats the way im going with mine and this is its second auto gearbox aching for manual and i reckon money and time well spent in that direction and not the one i chose before(auto replacement) good luck :mosh: Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted June 20, 2006 Know anyone with a manual conversion kit anywhere? Cheers. Quote Share this post Link to post Share on other sites
danutt 4 Report post Posted June 20, 2006 check trade me im gonna be looking for a kit soon 2 but not 2 soon only when this auto blows when i give it the boot when the cams done and chipped box proli wont last too long :rambo: Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted June 20, 2006 Good luck, exactly which box am I looking for, I know the 6's don't fit, but do all the getrag 240's go behind the M40, because the box behind the M10's is a 240 also isn't it? Thanks. Quote Share this post Link to post Share on other sites
gmccormack 0 Report post Posted June 20, 2006 A M10 box won't fit a M40 engine. There are 13 different 240's. You need a 240-BMO or 240-TBCU or 240-BCX Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted June 20, 2006 Thanks for that, I take it those letters will be stamped or printed on the plate on the box? Cheers Quote Share this post Link to post Share on other sites
