paulo 88 Report post Posted February 17 Hi there Wondering if someone has one of these available, or can point me in the right direction... I have a generic K+DCAN of unknown origin which has worked OK for me with ISTA, INPA etc, but I am needing to flash my e60 M5 DME with a euro tune, and my existing cable does not seem to be up to it. the cables are listed as "out of stock" on the bimmergeeks website. (My M5 has a replacement DME from a USA car and is still running the USA smog parameters, causing a check engine light as it thinks the car should have a DMTL pump) cheers paul Quote Share this post Link to post Share on other sites
Eagle 1778 Report post Posted February 18 Its just mainly a firmware update isnt it? Probably could do it yourself for way cheaper or find the relevant one on Aliexpress with some work Seems to be a lots of places selling them though. Here's a few i found: https://www.djwwautodiagnostics.co.uk/product/bmw-k-dcan-lead-switch-enhanced-firmware-bimmergeeks-protool-07---23 https://www.bimmertuningtools.com/product/btt-cable/ https://www.chaoscalibrations.com/store/CHAOS-BMW-K-DCAN-INPA-OBD2-USB-Cable-p410327542 Quote Share this post Link to post Share on other sites
exextatic 173 Report post Posted February 18 Updating the cable's firmware isn't too difficult either: https://www.sfbmwcoding.com/files/flashing_compatible_cable_ediabaslib.pdf Definitely don't attempt to update the DME without fixing the firmware first, from memory the clone adapters have a firmware bug that results in every 255th byte being corrupt. Quote Share this post Link to post Share on other sites
Jacko 2314 Report post Posted February 18 I have a genuine one, you can borrow it if that helps. Quote Share this post Link to post Share on other sites
paulo 88 Report post Posted February 18 Thanks for the information, guys - very helpful. Yes, I understand that the MSS65 DME from M6 / M5 are particularly vulnerable to bricking if the proper upgraded firmware cable is not used. @Jacko - thanks for your kind offer - my preference is to buy one outright, as I will likely be using it semi-regularly, but please PM me if you would consider selling it. Cheers Paul Quote Share this post Link to post Share on other sites
paulo 88 Report post Posted March 25 Hi Guys, just closing the loop on this in case someone is searching for one of these in the future... I ended up purchasing one from Chaos Calibrations in USA: https://www.chaoscalibrations.com/store/CHAOS-BMW-K-DCAN-INPA-OBD2-USB-Cable-p410327542 Timely delivery, reasonable price, and a nice quality unit. It is basically on a par with the Bimmergeeks cable in terms of updated chip / firmware etc it worked perfectly to flash the DME on my e60 M5 to Euro tune spec. cheers paul 1 Quote Share this post Link to post Share on other sites
