NZ_InFerno 397 Report post Posted March 9 (edited) SOLD 2006 BMW E87 130i M-sport, 3.0L six speed manual with RWD. 185k kms. White(AlpinWeiss 3)with Black(Boston) Leather interior. Pre-LCI. Japanese import with climate air, electric heated seats, HiFi Professional, Xenons, Idrive (upgraded modern screen with Carplay and Android Auto), window rain guards and fully featured M-sport with trims/bumpers/sill plates/wheel. Rear wiper delete. Regularly serviced and maintained. Major items like coils, starter, waterpump, mickey mouse flange, vvt solenoids, vvt motor and DISAs all done. There have been many engine parts and other items replaced with OE parts in the last 10,000 kms, mostly preventatively, for future enjoyment of the car. Full list of items and receipts available. After getting the car mechanically correct, I had begun doing cosmetic work this year, to get the car perfect. It's in good condition for its age. With a 195kw N52 3.0L straight six engine, manual RWD and 50/50 weight distribution means this a a very well handling and driving vehicle that puts a smile on your face every time you take it out on the road. While also being comfortable cruising along at the speed limit. This is an unexpected and reluctant sale, of a car I intended to keep for a long time. Enthusiast owned, it has been tastefully modified with parts of the highest quality to improve the ride, feel and driver experience. Just replacing the wheels/suspension and exhaust alone would cost at least 10k, before shipping, from Japan/Europe, and that's without the additional cost of certification, or taking into account the rare original BMW Performance parts on the interior and exterior. Modifications : K&N air filter and Turner Motorsports intake for better breathing. Work Emotion D9R staggered 18" Wheels in 5*120 stud pattern, with offset specifically ordered for this car special order from Japan. Recently refurbished. Supposedly the only set in 5*120 in NZ. Work no longer makes these wheels in 5*120 stud pattern. RE003 Tyres all round in good condition Supersprint Exhaust backbox, no longer being manufactured BMWP AERO Spoiler, No longer available from BMW Ohlins Road & Track Coilover Suspension System for BMW 1 series - front and rear Certified for Wheels/Suspension Alcantara mirror/instrument binnacle BMW Performance interior parts, handbrake cover/handle, shifter gaiter, pedals and BMW ZHP weighted shift knob. Most BMWP parts are no longer available from BMW Transmission Shifter Bushing upgrade to improve shift quality Android/Carplay idrive screen replacement Cosmetically, on the exterior there's a small dent in the left rear crease line. Slight damage to front bumper plastic next to license plate. Some stone chips on the front and very shallow dent on the roof from prior owners roof racks. Otherwise it's looks pretty good and cleans up well. The interior, everything is in good condition with several touch parts newly replaced. Headliner is sagging and has been pinned up. Steering wheel insert has some wear. Mechanically, sump gasket has a slight weep. I have many brand new OE and OEM parts for the car, roughly $1.5k worth (not including shipping costs) including a full sump gasket replacement kit, engine mounts, steering wheel leather, steering wheel inserts from BMW and BMWP, oil filters, bulbs, BMW and Work wheel caps, plus several others including duplicate parts. Everything is new in box except for the original BMW wheel caps. I also have used original BMW Roof racks for the car. All parts can be sold with the car at extra cost. $12000 or $13000 with all of the parts Edited March 30 by NZ_InFerno 1 3 Quote Share this post Link to post Share on other sites
NZ_InFerno 397 Report post Posted March 9 Parts replaced by mechanic or myself in the last 10k kms, 177k-185k kms, all with OE or OEM parts. And roughly in order of replacement. Cabin air filter PCV System and hoses MAF sensor Eccentric shaft sensor Chain and tensioners checked at 177xxxkms Rocker Cover Gasket Oil change/Service Electronic relay for valvetronic motor Valvetronic motor and fuses Spark Plugs x6 Coils x6 Front and rear driveshaft Guibos(couplings) Shifter bushings replacement(upgrade kit) Transmission Mounts New Diff oil & gearbox oil replaced at 180k kms Starter motor Intake manifold gaskets Idrive controller plastic surround Side indicators Oem tail lights full replacement Power steering reservoir and new fluid Oil Filter Housing Cooler Gasket Front Accessories Belt, Tensioner and idler pulley Replacement rear License Plate light Pierburg Oem VVT Solenoids Stabilus hood struts Schmiedmann upgraded brake lines all round - Outer lines front and rear TRW Front and Rear rotors Ceramic brake pads Front and Rear New brake screws, Rubber caliper slides, and brake hardware New brake fluid Wheel sensors front and rear Vanos Oil filters/Check valves x2 Meyle Boot struts All wheels refinished by Wheel Magician - 2025 Mickey Mouse Flange and Coolant Hose, new coolant - 2025 Oil Change w/Filter and Magnetic plug - March 2025 Told clutch has been replaced by previous owner Quote Share this post Link to post Share on other sites
topnotchrally 177 Report post Posted March 10 What are the 2 things on the right side of the centre console? Quote Share this post Link to post Share on other sites
Vass 1083 Report post Posted March 10 59 minutes ago, topnotchrally said: What are the 2 things on the right side of the centre console? Look like magnetic phone holders. Weird placement tho. Quote Share this post Link to post Share on other sites
NZ_InFerno 397 Report post Posted March 10 2 hours ago, topnotchrally said: What are the 2 things on the right side of the centre console? They were in the car when purchased, absolutely no idea what they are but best guess some sort of phone or device holder. Didn't want to remove them when I first got the car as they look to be glued to the trim. And they didn't interfere with driving. I had totally forgot they were in there, guess they just became part of the car over time lol Quote Share this post Link to post Share on other sites
Danch 54 Report post Posted March 15 Put this up on TM. It's free selling today 1 Quote Share this post Link to post Share on other sites
NZ_InFerno 397 Report post Posted March 16 This is now on Trademe: https://www.trademe.co.nz/a/motors/cars/bmw/listing/5220230667 Quote Share this post Link to post Share on other sites
NZ_InFerno 397 Report post Posted March 30 Sold 😭 Quote Share this post Link to post Share on other sites
