Accidental Bimmerer 9 Report post Posted April 3 (edited) A couple of years ago I saw a little white 2004 E46 316ti for sale on the side of the road near where I live. Asking $2500. But it had some panel scrapes down the left door & 3/4 panel, although not too obvious at a casual glance. After a test drive in the hills nearby, I offered $2000 and drove it home. A few days/weeks later I noticed puffs of smoke when driving around town. Sometimes quite a lot. One time waiting at the lights outside a packed Sprig & Fern it tried to lay down a smokescreen. Checking later I found the oil filler cap full of creamy gunk. I thought I'd blown a head gasket. A bit later the starter motor failed completely close to home. It was off the road for a few weeks as I sought instructions to take it out, and had to order some torx ring spanners from overseas to get the top bolt out. $400 for a new starter, and $100 for a new CCV valve with insulated hoses, I eventually got back on the road. $300 for a couple of new tyres, new WoF, and I was back on the road. The transmission is a bit of a reluctant up-shifter, and sometimes goes into diagnostic mode on cold mornings. I ordered a transmission filter from Latvia or somewhere, but it arrived with a damaged gasket. Got a refund without sending it back, and ordered another one from Aus. Got the Caltex oil waiting for me to feel in the mood for getting dirty. In the meantime I've got quite a nice little non-smoking motorcar. Not much poke, but heeeeaps of fun on a winding road like the Takaka Hill... A couple of days ago I saw a little silver 2006 E91 325i for sale on the side of the road near where I live. Asking $3000. But it had a slight ding in the driver's door and a couple of very minor defects, although not too obvious at a casual glance. After a test drive in the hills nearby, I offered $2600 and drove it home. Sh*t I hope it goes better this time... Edited April 3 by Accidental Bimmerer 3 Quote Share this post Link to post Share on other sites
Vass 1083 Report post Posted April 3 Sounds like a rough introduction, but on the bright side, you started off with one of BMW's worst engine from the past 20 odd years, so things can only go up from there. I'm willing to bet the valve stem seals will be shot on the little ti, very common issue on those N42 engines. Very tedious job replacing those, probably beyond the average DIY enthusiast and you do need some special tools. I've done it once and it took the better part of a weekend. You'll be looking at close to a $2k bill if taking it to a shop. The ti is a fun wee car but unfortunately the 4-cylinders in them are absolute pigs and are more trouble than they're worth. Either engine swap it or get rid would be my recommendation. I dare say you'll have a much better experience with the 6-cylinder, although not without its issues. Luck be with you! 1 Quote Share this post Link to post Share on other sites
elias 455 Report post Posted April 3 I owned a silver e91 325i for quite a few years and it was an awesome car that gave me only minor issues, the odd misfire from a bad ignition coil and a wheel speed sensor failed. Fantastic cars that are a pleasure to drive. Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted April 3 If your goals include money pits then it sounds like you are well on track Quote Share this post Link to post Share on other sites
Accidental Bimmerer 9 Report post Posted April 5 On 4/4/2025 at 2:25 AM, Vass said: Sounds like a rough introduction, but on the bright side, you started off with one of BMW's worst engine from the past 20 odd years, so things can only go up from there. I'm willing to bet the valve stem seals will be shot on the little ti, very common issue on those N42 engines. Very tedious job replacing those, probably beyond the average DIY enthusiast and you do need some special tools. I've done it once and it took the better part of a weekend. You'll be looking at close to a $2k bill if taking it to a shop. The ti is a fun wee car but unfortunately the 4-cylinders in them are absolute pigs and are more trouble than they're worth. Either engine swap it or get rid would be my recommendation. I dare say you'll have a much better experience with the 6-cylinder, although not without its issues. Luck be with you! Thanks Vass, it doen't smoke or burn much oil at all now. I think it was something to do with the CCV hoses being gunked-up, I believe the moisture condenses inside them on short winter runs? The replacements were insulated, which may be the solution. Quote Share this post Link to post Share on other sites
Accidental Bimmerer 9 Report post Posted April 5 On 4/4/2025 at 7:24 AM, elias said: I owned a silver e91 325i for quite a few years and it was an awesome car that gave me only minor issues, the odd misfire from a bad ignition coil and a wheel speed sensor failed. Fantastic cars that are a pleasure to drive. It seems good so far, drives beautifully. It does have the N52 'lifter tick', but from what I've read that's not fatal. The computer screen froze up on a run into town this evening, but it was working again on the return trip, although response seemed a little sluggish. Quote Share this post Link to post Share on other sites
Accidental Bimmerer 9 Report post Posted April 5 On 4/4/2025 at 10:21 AM, Eagle said: If your goals include money pits then it sounds like you are well on track That's why I like to buy seemingly-good, cheap cars - if it all turns to custard, I'll sell it to a dismantler and tolerate a small loss! Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted April 21 BMW will not reward you for continuing neglect! they need care and maintenance. If you prefer a cheaper car that will stand abuse, find a Camry, they'll take 30 years with just occasional care. Quote Share this post Link to post Share on other sites
