Tristan 338 Report post Posted September 7, 2010 A question most probably answerable by Glenn: This may seem petty but is it very easy to switch the steptronic from pushing it forward to shift up to pulling it back to shift up? It's nothing major but if it's a simple solution like inverting fuses (my basic mind at work) then I'll probably do it. Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted September 7, 2010 http://www.bmwtips.com/tipsntricks/reversi..._shift_patt.htm http://forums.bimmerforums.com/forum/showt...d.php?t=1395219 Apparently, Yes. Quote Share this post Link to post Share on other sites
Tristan 338 Report post Posted September 7, 2010 Cheers. Glenn or anyone else able to do this? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 7, 2010 Cheers. Glenn or anyone else able to do this? Never done it, neither have I been asked to do it. Someone else on here may have though Quote Share this post Link to post Share on other sites
|ncary 0 Report post Posted September 8, 2010 (edited) anyone know which wires need to be connected to start a facelift e30 car after auto to manuel?? tried searching to no avail. cheers Edited September 8, 2010 by Incary Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted September 8, 2010 It appears to be.... Green/Yellow to Green/Black Could be wrong tho. Quote Share this post Link to post Share on other sites
5amchris 45 Report post Posted September 8, 2010 E36 328i Very loud brakes only when they get hot. when you press the brakes hard they dont make any sounds at all but small braking its very loud starting to piss meh off ='[ What can this be? Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted September 8, 2010 ^scored rotors? glazed rotorts and or pads? pad level indicator? a stone stuck in the pad or calliper. any or all of the above. Quote Share this post Link to post Share on other sites
J~~ 0 Report post Posted September 8, 2010 Does the E36 Window Regulator Pivot Adjusment Bar White round plastic slider come off? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 8, 2010 If your meaning the two slides on the end of the two regulator arms thats attach the regulator to the bottom of the window....yes they come off. Remove the two metal circlips and pull the ball socket out of the slides. Slide the slide clips out, grease the runners and fit new slides. You will need small polley grips to get the ball socket back into the new slides. Quote Share this post Link to post Share on other sites
J~~ 0 Report post Posted September 9, 2010 If your meaning the two slides on the end of the two regulator arms thats attach the regulator to the bottom of the window....yes they come off. Remove the two metal circlips and pull the ball socket out of the slides. Slide the slide clips out, grease the runners and fit new slides. You will need small polley grips to get the ball socket back into the new slides.Thanks for the reply Glenn. But I was talking about the other sliding plastic thing, the rail comes with the Regulator. Sorry I'm pretty new to this.But they have it in a picture here http://www.dvatp.com/bmw/diy/power_window/ Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 9, 2010 Thanks for the reply Glenn. But I was talking about the other sliding plastic thing, the rail comes with the Regulator. Sorry I'm pretty new to this. But they have it in a picture here http://www.dvatp.com/bmw/diy/power_window/ Give me a call in the morning (09) 2722546... I think were talking about the same thing Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted September 11, 2010 On a E30, the single thick red wire is power to the alternator right? Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted September 11, 2010 No power goes to the alternator Nath, it generates power. I believe it goes to the battery positive, but someone else will confirm. Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted September 12, 2010 ^ Yeap thats sort of what I mean't haha, that'l do. And yip it does go to battery + Thanks Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted September 12, 2010 it goes from the battery to the starter motor, there are 2 wires off the starter motor, one goes to fusebox etc and one to the back of the altinator. sometimes the fusebox wire runs either from the battery terminal in the front or from a joining point on the firewall also. Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted September 17, 2010 Anyone know if a E30 boss kit fits a E21? Are the splines the same size? Cheers Quote Share this post Link to post Share on other sites
Guest Simon* Report post Posted September 17, 2010 Now that's an interesting question coming from you Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted September 18, 2010 putting the interior of the E30 back together, got a bit of an oil spill on the back seat (leather) pretty sure its brake fluid. any idea how to remove the stickyness? dont want to damage the leather if i can help it, though i fear i have already done so btw after typing this, i swear the stickyness on the backseat is definately originted from a bottle ;p Quote Share this post Link to post Share on other sites
Jacko 2356 Report post Posted September 19, 2010 Will a large case diff fit into an E30? Im assuming the difference in length can be adjusted on the driveshaft? Would the output flanges be the same as my 85 323 with med case 3.23:1 diff? Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted September 19, 2010 Nope, only small or medium fit sadly Quote Share this post Link to post Share on other sites
Jacko 2356 Report post Posted September 19, 2010 Stink Quote Share this post Link to post Share on other sites
Jacko 2356 Report post Posted September 19, 2010 http://www.trademe.co.nz/Trade-Me-Motors/C...n-318221551.htm ? Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted September 19, 2010 ^thats a medium case, and a good price too Quote Share this post Link to post Share on other sites
Jacko 2356 Report post Posted September 19, 2010 ^thats a medium case, and a good price too Ahhk for some reason I thought 8 bolt was large, 6 was medium? Quote Share this post Link to post Share on other sites
