jay^ 1 Report post Posted December 22, 2011 my two local repco stores both have them. maybe they are just out of stock? Supercheap local? According to the narva book at the repco in mt wellington they dont even stock them ? Ill try segedins Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted December 24, 2011 If your car's not any lower than previously, those are bump stops, whoever your local auto dist. is should have replacements, although its a pain to put new ones in as as everything else needs to come out. Cheers Lucan, i may just replace shocks and springs at the same time. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted December 24, 2011 According to the narva book at the repco in mt wellington they dont even stock them ? Ill try segedins Hmm i got some for my clear indicators on my e34. If continued no luck and you still have the ones that are blown out, see if it says what brand it is and google that for the supplier Quote Share this post Link to post Share on other sites
flake 0 Report post Posted December 29, 2011 Really dumb question but is there an o-ring seal for an e30 FL dipstick tube into the block? I've pulled out a PFL one with no o-ring., just metal to metal, grease and dust holding it in. Was a prick to get out. http://realoem.com/bmw/showparts.do?model=...hg=11&fg=10 or http://realoem.com/bmw/showparts.do?model=...hg=11&fg=10 Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 29, 2011 (edited) It shows an "O" ring on the diagram and also in ETK (No9) but the part is not fitted and does not apply to a F/L or P F/L block. Clean the surface and add a liitle sealant to seal it. Edited December 29, 2011 by *Glenn* Quote Share this post Link to post Share on other sites
flake 0 Report post Posted December 29, 2011 Brilliant, thanks Glenn. Quote Share this post Link to post Share on other sites
byza213 1 Report post Posted January 8, 2012 my cigarette lighter thing had a random blow , now the actual lighter thing is not fitting in place any more also should i just replace the unit if that's possible? Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted January 15, 2012 my cigarette lighter thing had a random blow , now the actual lighter thing is not fitting in place any more also should i just replace the unit if that's possible? I would think so, have had the same issue before! Hey guys, do e36 318is shocks and springs fit my e36 318i? Cheers Quote Share this post Link to post Share on other sites
byza213 1 Report post Posted January 24, 2012 I would think so, have had the same issue before! yea ended up changing fuse worked fine , used iPhone charger fine , used cigi lighter again blows fuse i don't smoke so im leaving this one out for now, its just for music Quote Share this post Link to post Share on other sites
byza213 1 Report post Posted January 24, 2012 recently a clicking noise started in the rear when turning left , after a week or so its clicking turning both sides. click click click until i straighten up , no knocking sounds or anything any thoughts on what to check? its pissing me off Quote Share this post Link to post Share on other sites
leithcm 0 Report post Posted January 24, 2012 recently a clicking noise started in the rear when turning left , after a week or so its clicking turning both sides. click click click until i straighten up , no knocking sounds or anything any thoughts on what to check? its pissing me off If I didn't know any better it sounds like your CV's are stuffed......... Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted January 26, 2012 Are the Z3 underbody cross braces the same as any other E36 ones? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 26, 2012 Are the Z3 underbody cross braces the same as any other E36 ones? ETK should tell you Greg Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted January 26, 2012 You probably could to, i'm not at work this week. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 26, 2012 Just had a look...E36Z3 has same front components. X brace Part # 51718410212. I had a look at E36, it shows the same diagram but says its not applicable. It shows exactly the same diagram for M3 & M3 evo but doesn't list a part # Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted January 26, 2012 Ok thankyou. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 26, 2012 Another thread recently was about fitting these. Can't remember what category the thread was in. I'm pretty sure you can fit the Z3 brace to a E36 though Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted January 26, 2012 I've got one lying around here, it has a sump protector on it too which is the main reason. Might attempt to fit it when i have it on the hoist next. Cheers Glenn. Quote Share this post Link to post Share on other sites
brockie123 31 Report post Posted February 2, 2012 I am currently putting a pfl m20b25 into a fl using I facelift loom I understand I have to put the facelift front pully and crank angle sensor on, but I see the pfl has a dowl but the face lift doesn't how can I swap these over making sure everything is correct? Quote Share this post Link to post Share on other sites
Docile 64 Report post Posted February 7, 2012 (edited) on ignition on the 740 i just noticed last week that the oil light sometimes dont light especially on cold starts, and sometimes it does (ignition 2). oil level is good and no leaks. anyone know what it could be? oil pump going kaput? it has done 265ks Edited February 7, 2012 by Docile Quote Share this post Link to post Share on other sites
thirdkide30 0 Report post Posted February 9, 2012 Can you take a pic of the bracket in the car without all the tape on it ? You might have p/fl bracket and f/l switch Well have tried doing what was said about the brake light switch and doesnt seem to fit and yes both are for f/l. Bracket is square type. But i have cable tied it in place and is alright for now.But now my problem is the tensioner bolts for the alternator seems to have been threaded causing the belt to be loose. Is this an easy replacement? Quote Share this post Link to post Share on other sites
shaneg 0 Report post Posted February 10, 2012 Anyone couriered a front bumper? Looking to go between islands? Will ask couriers but if someones done it before would save a lot of time. Quote Share this post Link to post Share on other sites
thirdkide30 0 Report post Posted February 10, 2012 Anyone couriered a front bumper? Looking to go between islands? Will ask couriers but if someones done it before would save a lot of time. I have couriered a whole complete conversion (gbox and etc) from chch to aux. Theyll pick it up and etc but the receiving end has to pick it up from them. Stealth logistics is pretty good.. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted February 10, 2012 if someone can pickup and drop off at each end, you cant beat the train if its between islands. I have used Toll Quote Share this post Link to post Share on other sites
shaneg 0 Report post Posted February 10, 2012 I have couriered a whole complete conversion (gbox and etc) from chch to aux. Theyll pick it up and etc but the receiving end has to pick it up from them. Stealth logistics is pretty good..what price? obviously this will weigh a lot less, just awkward shape.if someone can pickup and drop off at each end, you cant beat the train if its between islands. I have used TollThats a good idea, only im in qtown.. no trains unless i go to dunedin.. in saying that my mates brought drives a train.. Hmm. Quote Share this post Link to post Share on other sites
