pureboiracer 0 Report post Posted May 29, 2007 the bolt is usualy denser than the metal it is bolting into so when you heat it the metal around it expands more than the bolt thus freeing it up. anyone know how to tell what ecu i need to get for my 1987 325i motor. it has got 2 rows of pins on the loom conector. and if i can use my pfl flywheel from my 320i????? Quote Share this post Link to post Share on other sites
jpp 0 Report post Posted June 15, 2007 Few things regarding e30 coupe fl 318iA; Mates borrowing my red book, so... A) Removed battery, replaced, now the 'service lights' stay on fully green. What does this mean? Rev counter doesn't work, yet speedo does. Simple fix = ___? C) I need to access the boot, yet the lock has been attempted to be broken into, and now the key won't work. Best idea I've come up with is remove rear seat, remove ski hole, then remove the 2 bolts on each side holding the boot down, but still will have lock attached right? Next idea? Destroy the lock all together? That's it for now, thanks. Quote Share this post Link to post Share on other sites
Brennan 0 Report post Posted June 16, 2007 hi guys just took the clutch out of my parts car and it measures 8.3mm thick (accurately). My manual says 7.5mm is the minimum. Is that much room? I have no idea what to compare it to and how quickly clutches wear? thanks Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted June 16, 2007 Its fine. Keep it. They're pretty cheap though. If you actually needed a new clutch you may as well buy new. There's nothing wrong with having a serviceable spare lying around though. Quote Share this post Link to post Share on other sites
Steve K-B 51 Report post Posted June 25, 2007 A quick one: What are the tappet settings on an e30 6cyl? Ive seen 12 thou but this looks to much to me.... Cheers. Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted June 25, 2007 10 thou cold, 12 thou hot according to Bentley. Quote Share this post Link to post Share on other sites
Steve K-B 51 Report post Posted June 25, 2007 Awesome, ill give 10 a shot. thanks Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted June 26, 2007 Is the viscous fan in the 318 and the 320 the same? Cheers. Quote Share this post Link to post Share on other sites
B*Emz 0 Report post Posted June 26, 2007 What size are the front speakers in an NZ new pre f/l m325? In the footwells behind the kick panels. Finally onto sorting audio and what to know what size components I can fit behind there. Quote Share this post Link to post Share on other sites
jpp 0 Report post Posted June 26, 2007 What size are the front speakers in an NZ new pre f/l m325? In the footwells behind the kick panels. Finally onto sorting audio and what to know what size components I can fit behind there. Mine had 5.25", but some can fit 6"+ in it. Quote Share this post Link to post Share on other sites
B*Emz 0 Report post Posted June 26, 2007 Mine had 5.25", but some can fit 6"+ in it. Thanks Jared, Who's got 6"s in there without cutting/destroying things? Quote Share this post Link to post Share on other sites
jpp 0 Report post Posted June 26, 2007 You have to make some damage. I've got some door cards that'll come with dash if you wanna practice cutting? On another note; How do I track down an address "legally" with just the persons phone number in NZ?? Also; What companies out there in the world wide auckland pick-up wrecked cars [non-rolling] with a hiab, bonus points if you name one that pays [or does free]. Quote Share this post Link to post Share on other sites
B*Emz 0 Report post Posted June 26, 2007 You have to make some damage. I've got some door cards that'll come with dash if you wanna practice cutting? It's all good thanks, I'm not letting them go near door cards anyway- Danke Jared Quote Share this post Link to post Share on other sites
Katalyst 0 Report post Posted June 26, 2007 Who's got 6"s in there without cutting/destroying things? have got 6 1/4s in, had to cut out the kickpanel plastic speaker grill, and to retain the bonet release cut into the glovebox to allow to open properly - could avoid by having a rip cord style bonet release (way less effort than chopping up glovebox) or a more slim speaker have infinty reference's in, which i belive are on the bigger side could take some pics if u like? Quote Share this post Link to post Share on other sites
Huttey 0 Report post Posted June 26, 2007 could take some pics if u like? I'm looking at doing mine and would appreciate some pictures Quote Share this post Link to post Share on other sites
B*Emz 0 Report post Posted June 26, 2007 I'm anti cutting/hacking into anything, so I imagine I'm going to have to go smaller- Thanks though! I'm on a no-destruction-mission currently, trying to keep everything looking smooth Quote Share this post Link to post Share on other sites
Katalyst 0 Report post Posted June 26, 2007 yeah tried to go that way, but didnt want to smaller in speakers, its just that stupid bonnet lever!!!! the whole thing is only just out, have almost finished it thou!! i guess the best thing to do is to measure the gap between the kick panel and the bonnet release and then goto a car audio shop and measure the cover depth of the speakers and then choose out of those that fit. mounting depth isnt great in e30s either!!! Quote Share this post Link to post Share on other sites
Katalyst 0 Report post Posted June 26, 2007 I'm looking at doing mine and would appreciate some pictures sweet will take some 2moro, but wont be up till late 2moro nite Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 26, 2007 Is the viscous fan in the 318 and the 320 the same? Cheers. The differences are only 3 or 4 stud.... Quote Share this post Link to post Share on other sites
Katalyst 0 Report post Posted June 27, 2007 I'm looking at doing mine and would appreciate some pictures have posetd a new topic here Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted June 28, 2007 (edited) Or you could cut the bonnet release to half thickness - still plenty strong enough. i have the same speakers and they look almost factory - cut kickpanels and modded release lever. If you want to go baller hook the cable up to a solenoid and have electric bonnet release. If your batt is flat use the emergency method using a flat blade screwdriver on the latch (legit). The prob with 5.25" components is that there are bugger all to choose from. Edited June 28, 2007 by bravo Quote Share this post Link to post Share on other sites
Katalyst 0 Report post Posted June 28, 2007 yeah thought about slicing in half but wasnt sure if it would be strong enuff, but ohwell, enjoy tinkering around with things works - sounds good - happy Quote Share this post Link to post Share on other sites
joel 0 Report post Posted July 4, 2007 Hi, am wanting to check the gear box oil level as it has been leaking on my E30. Do I need a 17mm allen key to open this? 10mm was the biggest I could find in Super Cheap. Cheers, Nick Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted July 4, 2007 Yeah you need a big bugger. Go to a tool shop and buy the right size - get the type that fits on a ratchet driver - not the "L" shaped ones. Or buy a set. Forget the size - measure carefully, or someone else here may know offhand. Quote Share this post Link to post Share on other sites
jpp 0 Report post Posted July 9, 2007 Why would a instrument cluster on a '85 323i's lights stop working on a 'replaced', unsure if replaced new, yet the speedo/tacho still work, but fuel is unaccurate... S.I batteries or a fuse was my guess, haven't been checked, anyone _know_ what it is? Quote Share this post Link to post Share on other sites
