westy 614 Report post Posted April 17, 2007 Linky Why you cant dyno obd2 cars. Quote Share this post Link to post Share on other sites
bravo 34 Report post Posted April 17, 2007 >As you see, at no point did the post curve dip under the pre curve and also >that the most notable gains were up to about 4400 rpms. ( also the worthless >gains above 5500 rpms ). Worthless gains above 5500?? (the words "agent provocateur" comes to mind!) Post the numbers above 6000, wouldja... Because those "worthless gains" will save significant time off your 0-60... On a BMW, the revs above 5500 aren't there to LOOK AT.. they are there to DRIVE..every day.. Try this: 1st.. redline.. 2nd.. redline.. 3rd.. Then get back to us.... Jim C. nice. Quote Share this post Link to post Share on other sites
Kpax 0 Report post Posted August 31, 2007 Hey dudes, Where is the closest Dyno place to me? I'm in Gfield, Nrth Shore. I think there is one somewhere on Porana Road but don't know what's da name. Any clue ??? Quote Share this post Link to post Share on other sites
BM WORLD 1265 Report post Posted August 31, 2007 Hey dudes, Where is the closest Dyno place to me? I'm in Gfield, Nrth Shore. I think there is one somewhere on Porana Road but don't know what's da name. Any clue ??? Gavin Bellars Hi Velocity Ltd 09 4424451 Quote Share this post Link to post Share on other sites
BM WORLD 1265 Report post Posted August 31, 2007 A new sticky thread. Post up your engine power/torque [measured at the wheels] and 1/4 mile times. Must be accompanied with Dyno graph and drag slip times. Please convert to kW and trap times to kph List will constantly be updated. Right now i'm just going off the top of my head on some powers so we will correct the list as it gets updated by members. Darren [sR20DET] - E30/240 kW (?) 1/4 ET: (?) Glenn [E30323Ti] - E30/2JZ-GTE - 218 kW (?) 1/4 ET: (?) Andrew - E30/M42 Turbo - 190 kW (?) 1/4 ET: 13.99 (with car problems and much less power) Cain [cainchapman] E34/m60 4.0 - 172 kW 1/4 ET: 14.78 Andrew - E30/m20 2.5 - 138 kW 1/4 ET: (?) Tim [bumpstop325] E30/m30 3.5 - 133 kW 1/4 ET: (?) Gus - E30/m20 2.5 - 111 kW 1/4 ET: (?) 2002 - 2002/m10 2.0 - 72 kW 1/4 ET: (?) martyns (top cat ) e28 86 M535i turbo rough tune 253Kw 12Ibs . dont know torque (but it feels likes heaps)..my e28 M535i with M5 engine only did 153Kw 345Nm , but that is with 3.07 diff have just fitted 3.73 diff should be better now. Quote Share this post Link to post Share on other sites
Andrew 30 Report post Posted September 1, 2007 A new diff won't get you more power Quote Share this post Link to post Share on other sites
BM WORLD 1265 Report post Posted September 1, 2007 A new diff won't get you more powergavin wreckons different results , like changing wheels etc higher gearing is like turning bigger/heavier wheels etc .same power at flywheel but different results measured at the wheels . Quote Share this post Link to post Share on other sites
Mike 1 Report post Posted September 2, 2007 I really can't see how it will change. horsepower is torque x rpm. as you know changing a diff will change torque to the wheels, but will also change rpm accordingly and should result in the same power, The same should also be true for the torque if you run in a 1:1 gear and account for the diff ratio each time. Quote Share this post Link to post Share on other sites
drifty325i 0 Report post Posted December 13, 2007 Darren [sR20DET] - E30/240 kW (?) 1/4 ET: (?) Glenn [E30323Ti] - E30/2JZ-GTE - 218 kW (?) 1/4 ET: (?) Riley-{drifty340}-E30/1UZFE V8 -208kw 1/4 ET (?) Andrew - E30/M42 Turbo - 190 kW (?) 1/4 ET: 13.99 (with car problems and much less power) Cain [cainchapman] E34/m60 4.0 - 172 kW 1/4 ET: 14.78 Andrew - E30/m20 2.5 - 138 kW 1/4 ET: (?) Tim [bumpstop325] E30/m30 3.5 - 133 kW 1/4 ET: (?) Gus - E30/m20 2.5 - 111 kW 1/4 ET: (?) 2002 - 2002/m10 2.0 - 72 kW 1/4 ET: (?) Quote Share this post Link to post Share on other sites
IPLEZR 0 Report post Posted December 13, 2007 Darren [sR20DET] - E30/240 kW (?) 1/4 ET: (?) Glenn [E30323Ti] - E30/2JZ-GTE - 218 kW (?) 1/4 ET: (?) Riley-{drifty340}-E30/1UZFE V8 -208kw 1/4 ET (?) Andrew - E30/M42 Turbo - 190 kW (?) 1/4 ET: 13.99 (with car problems and much less power) Cain [cainchapman] E34/m60 4.0 - 172 kW 1/4 ET: 14.78 Andrew - E30/m20 2.5 - 138 kW 1/4 ET: (?) Tim [bumpstop325] E30/m30 3.5 - 133 kW 1/4 ET: (?) Gus - E30/m20 2.5 - 111 kW 1/4 ET: (?) 2002 - 2002/m10 2.0 - 72 kW 1/4 ET: (?) My e30 at the moment running 12psi at a 65% tune is putting out 270hp at the wheels and has done a 13.42 at night speed on all 4 chromes. was doing 174.something km/h at the speed trap. still in need of retune at higher boost etc but not bad for now. Quote Share this post Link to post Share on other sites
morerevsm3 7 Report post Posted January 3, 2008 NA (for now) S50B30 199.6RWKW 12.971 @ 170.55kph Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted January 3, 2008 very nice! is that stock? v nice 1/4 too Quote Share this post Link to post Share on other sites
morerevsm3 7 Report post Posted January 3, 2008 very nice! is that stock? v nice 1/4 too just a few bolt ons, have reduced car weight quite a bit since running at drags last (mostly do circuit clubsprints/hillclimbs/motorkhanas etc) so I think 12.7 is achievable now Quote Share this post Link to post Share on other sites
drifty325i 0 Report post Posted January 3, 2008 just a few bolt ons, have reduced car weight quite a bit since running at drags last (mostly do circuit clubsprints/hillclimbs/motorkhanas etc) so I think 12.7 is achievable now Thats very quick considering your mods, you must be stoked tho Quote Share this post Link to post Share on other sites
cainchapman 0 Report post Posted January 3, 2008 Damn, I've finally been knocked off the top NA spot. Those are great times. Run on road tyres? or a race compound (DOT rated)? I need to get those intake and exhaust mods done and see if I can retake the lead. Quote Share this post Link to post Share on other sites
drifty325i 0 Report post Posted January 3, 2008 (edited) Damn, I've finally been knocked off the top NA spot. Those are great times. Run on road tyres? or a race compound (DOT rated)? I need to get those intake and exhaust mods done and see if I can retake the lead. Im pretty sure i took that off you a few weeks ago Cain or are you refering to the 1/4 hehe ill sort that soon to Edited January 3, 2008 by Drifty 340i V8 Quote Share this post Link to post Share on other sites
cainchapman 0 Report post Posted January 3, 2008 (edited) Well, I was referring to BMW powered cars Riley, and yours has an estimate of power at the Flywheel, whereas mine is at the wheels. The 540 is 214kW at the flywheel, so I win on that basis still (compared to your beast). I'll look forward to the 1/4 mile time. You'll have to get it around Ruapuna and compare lap-times. The 540 has done a 1 minute 53 second time. (full track, excluding dipper) Edited January 3, 2008 by Cain Quote Share this post Link to post Share on other sites
drifty325i 0 Report post Posted January 3, 2008 Well, I was referring to BMW powered cars Riley, and yours has an estimate of power at the Flywheel, whereas mine is at the wheels. The 540 is 214kW at the flywheel, so I win on that basis still (compared to your beast). I'll look forward to the 1/4 mile time. You'll have to get it around Ruapuna and compare lap-times. The 540 has done a 1 minute 53 second time. (full track, excluding dipper) no no mine is 279.1hp/208kw at the wheels, i thought it was at the fly but its not.dynapac dyno i was very suprised to dont worry. So mines more like 250kw at the fly est. Yes im really lookin forward to gettin it back out there! been along time since ive had that car out there Quote Share this post Link to post Share on other sites
cainchapman 0 Report post Posted January 4, 2008 Getting another 30kW out of the 4 litre might be a bit of a stretch for me. I guess 210kW at the wheels in my new target then. I'll let you know as I get more. I'll look forward to seeing your car sometime too. Quote Share this post Link to post Share on other sites
morerevsm3 7 Report post Posted January 4, 2008 Damn, I've finally been knocked off the top NA spot. Those are great times. Run on road tyres? or a race compound (DOT rated)? I need to get those intake and exhaust mods done and see if I can retake the lead. run 13.02 @ 106.48mph on goodyear eagle F1 G3's with 1.8x 60', 12.982 on Kuhmo ecsta V700(1.797 60'), have some drag radials now, but only got a couple of runs before I snapped driveshaft bolts, can still launch harder yet weight of me and car- Quote Share this post Link to post Share on other sites
cainchapman 0 Report post Posted January 4, 2008 Ah, Mickey Thompson's. And running 15" too. You are serious about those times. I must go and get the car and myself weighed too. I'll be about 300kg heavier. Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted January 4, 2008 no no mine is 279.1hp/208kw at the wheels, i thought it was at the fly but its not.dynapac dyno i was very suprised to dont worry. So mines more like 250kw at the fly est. Yes im really lookin forward to gettin it back out there! been along time since ive had that car out there ahhh dynapack dyno so thats not quite correct either.....the dynapacks calculate a PS horsepower figure I beleive.My 535 measured about 140kw at rear wheel,but apparently this is not correct....i thnk there is a pot about this earlier in this thread around where i published my results. Quote Share this post Link to post Share on other sites
mr E34 11 Report post Posted January 4, 2008 ahhh dynapack dyno so thats not quite correct either.....the dynapacks calculate a PS horsepower figure I beleive.My 535 measured about 140kw at rear wheel,but apparently this is not correct....i thnk there is a pot about this earlier in this thread around where i published my results. The only way to compare approx power between cars is the use of the same dyno on the same day with the same operator. Quote Share this post Link to post Share on other sites
morerevsm3 7 Report post Posted January 4, 2008 The only way to compare approx power between cars is the use of the same dyno on the same day with the same operator.trap speed and known vehicle weight (including driver) are fairest comparison... Quote Share this post Link to post Share on other sites
drifty325i 0 Report post Posted January 4, 2008 Getting another 30kW out of the 4 litre might be a bit of a stretch for me. I guess 210kW at the wheels in my new target then. I'll let you know as I get more. I'll look forward to seeing your car sometime too. Ill take ya for a spin in it next time ya down mate Quote Share this post Link to post Share on other sites
