Greg111 13 Report post Posted May 11, 2008 Not too sure if this has been posted before but i'm after a way to reset my service light as i do all my own servicing etc, Jeff Grey BMW charge $50 and half an hour just to do that, i think there is a special tool you can purchace but after a cheaper way (if possible) Any help appreciated. Greg. Quote Share this post Link to post Share on other sites
greenday-rulz21 6 Report post Posted May 11, 2008 (edited) What you will need to do is connect pins 7 and 19 with a paperclip for four seconds. This will reset the oil service light. Here is the list of pins and what they are supposed to do: Pin Description 1 - TD Signal 2 - Not occupied 3 - Not occupied 4 - Not occupied 5 - Not occupied 6 - Not occupied 7 - Service Interval Reset 8 - Not occupied 9 - Not occupied 10 - Not occupied 11 - Not occupied 12 - Generator Charge Indicator 13 - Not occupied 14 - Voltage; Hot At All Times 15 - Diagnostic Data Link 16 - Voltage; Ignition Switch in Run 17 - Not occupied 18 - Programming Line 19 - Ground 20 - Diagnostic Data Link OK, using a paperclip, Bend your paperclip it so it looks like this: Use pliers if you have to. Turn the ignition key to position II, but don’t start the car. Get out of the car and go to the data port. Always connect pin 7 first. Once you’ve inserted one end into pin 7, insert the other end into pin 19 and hold it there for 4 seconds. Then remove the paperclip. Check the dash and the oil inspection lights should be reset. The reset occurs upon removal of the clip. IMPORTANT: DO NOT HOLD IT THERE FOR LONGER THAN 10 SECONDS or you may inadvertently reset your inspection I/II interval. Edited May 11, 2008 by Nick021 Quote Share this post Link to post Share on other sites
elmarco 56 Report post Posted May 11, 2008 Or you could try: http://www.trademe.co.nz/Trade-Me-Motors/C...n-153981494.htm Quote Share this post Link to post Share on other sites
Creaver 55 Report post Posted May 11, 2008 Sticky? Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted May 11, 2008 i think there is a special tool you can purchace but after a cheaper way (if possible) Here's the special tool: Quote Share this post Link to post Share on other sites
3 SERIES 93 Report post Posted May 11, 2008 Hi Greg, This is what Jeff Grey use. http://www.trademe.co.nz/Trade-Me-Motors/C...n-154619902.htm Dont be a monkey and use a paper clip! Will only end in tears! Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted May 12, 2008 That tools pretty expensive just to reset the service light or does it do other things too? Obviuosly i don't want to fry my electrics if i try do the pin 7 and 19 but it does seem pretty easy to do? Quote Share this post Link to post Share on other sites
Braeden320 0 Report post Posted May 12, 2008 I have one of these Works Well. Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted May 12, 2008 I don't know as I havn't pulled one apart, but at a guess those cheap tools on trademe just have a pcb inside with a couple of resistors and a fuse. I wouldn't use a paper clip, but I DO use a bit of fused wire. Works every time and safe. The only benefit of the tool is you can't get the wrong pins by mistake. The tool BMW use is also a diagnostic tool etc. Quote Share this post Link to post Share on other sites
3 SERIES 93 Report post Posted May 12, 2008 Whats your car worth again?????? I really dont think $74 is all that expensive in the whole scheme of things Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted May 12, 2008 good point, but my house is worth more and I still paint it myself, and fix the plumbing etc. If you want to be dead sure you are not going to cock it up buy the over-priced gizmo (that is possibly poorly made and prone to failure anyway). Or if you have a few clues, and use some common sense, DIY all the way baby. Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted May 12, 2008 if it's just for resetting service lights - piece of wire all the way! just make sure you put the wire in the right holes. Quote Share this post Link to post Share on other sites
Cale 36 Report post Posted May 12, 2008 I wouldn't use a paper clip, but I DO use a bit of fused wire. Works every time and safe. I just use a wire too but no fuse, how many Amps is the fuse you use? Quote Share this post Link to post Share on other sites
*rUstY_nUts* 9 Report post Posted May 12, 2008 I just use a wire too but no fuse, how many Amps is the fuse you use? 7.5 amp Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted May 12, 2008 (edited) Well there you go, piece of wire with a 7.5 amp fusable link, nothing could go wrong then, just gotta put it in the right hole Cheers for the advise guys. Edited May 12, 2008 by Greg111 Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted May 12, 2008 Like Bravo, I use a bit of fused wire, never had a problem, done quite a few now. Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted May 12, 2008 7.5 amp fuse - Nothing go wrong -Don't bank on it. May as well use a nail. More like a 1 amp for protection Otherwise -paper clip or whatever BUT just - don't get it wrong Quote Share this post Link to post Share on other sites
3 SERIES 93 Report post Posted May 12, 2008 Agreed, Dont get it wrong Greg! Otherwise you'll be crying all the way to the bank and that $74 Draper Tool wouldnt seem so expensive after all Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted May 12, 2008 I have a 2 amp in mine. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 12, 2008 Personaly I wouldn't use any type of wire I only suggested 7.5 amp fuse as anything is better than nothing... you will still do damage using a 7.5 amp fuse if you do it wrong. However the fuse might stop you burning yourself while you cock it up. Quote Share this post Link to post Share on other sites
3 SERIES 93 Report post Posted May 12, 2008 Ha ha. Good to see there is one other person here that's not a cowboy! Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 12, 2008 Ha ha. Good to see there is one other person here that's not a cowboy! I cant afford to be Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted May 14, 2008 Haha not a cowboy, havent done anything yet, on the fence now. Quote Share this post Link to post Share on other sites
