KEYMAN 0 Report post Posted July 16, 2008 hi , i would like to ask anyone in here about bmw model e46 320i . I just comfuse about da pedal acceleration on my car is so heavy and it's connection to the valve on da back of my muffer ???? I had try on e46 318i is very light and dont need you to pushing hard on da pedal like 320i ...... Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted July 17, 2008 English language pwns you But try spray some Dry-Glide into the accelerator cable near the pivot ( sorry don't really know the right word) and if not,maybe a small bit of lube behind the pivot on the acc pedal itself? Have no idea what the Muffer part is... Share this post Link to post Share on other sites
3series 0 Report post Posted July 17, 2008 get professional advice before you do anything to your car. Share this post Link to post Share on other sites
jjs 64 Report post Posted July 17, 2008 I think the factory may have made it stiff for a reason. Not everyone can handle the brutal thrust of a 320i at kickdown... Share this post Link to post Share on other sites
Greg111 13 Report post Posted July 17, 2008 I think the factory may have made it stiff for a reason. Not everyone can handle the brutal thrust of a 320i at kickdown...Haha, mines also heavy, better that way imo. Share this post Link to post Share on other sites
OLLIE 26 Report post Posted July 17, 2008 English language pwns you But try spray some Dry-Glide into the accelerator cable near the pivot ( sorry don't really know the right word) and if not,maybe a small bit of lube behind the pivot on the acc pedal itself? Have no idea what the Muffer part is... yeah what he said, just lube up the outer lip a bit and slide it in, slide it in and out a few times though to be sure. Share this post Link to post Share on other sites
Greg111 13 Report post Posted July 17, 2008 yeah what he said, just lube up the outer lip a bit and slide it in, slide it in and out a few times though to be sure. Share this post Link to post Share on other sites
OLLIE 26 Report post Posted July 17, 2008 make sure you use water based lube though, oil based can cause irritation and also cause the rubber to break Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted July 17, 2008 make sure you use water based lube though, oil based can cause irritation and also cause the rubber to break HaHa... you had lots of experience there Ollie ??? Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted July 17, 2008 get professional advice before you do anything to your car. Would a "shrink" be appropriate ??? Share this post Link to post Share on other sites
KEYMAN 0 Report post Posted July 18, 2008 I JUST SOLVE OUT A PROBLEM ON YESTERDAY. I HAD TO CHANGE A NEW CABLE TO REPLACE THE OLD ONE AND IT'S SO REALLY BETTER NOW... HAHAHHA..... I WILL POST A PICTURE OF OLD CABLE LATER...IT'S LOOK SO BAD INSIDE ....MANY THANK FOR YOU GUY ..... Share this post Link to post Share on other sites
3 SERIES 93 Report post Posted July 18, 2008 (edited) Not a problem, pleased we could be of some assistance Edit: grammer. Don't want to be caught out on this thread. Edited July 18, 2008 by 3 SERIES Share this post Link to post Share on other sites
