Mike
oil spots
Was playing around with the car, forgot a washer and got a trail of small oil spots up the asphalt driveway. Any one know of any easy way to get rid of them?
cheers
Engine degreaser and a hose.
FWIW, the passage of time will do a pretty good job too if it's exposed to the elements.
I have the same prob, oil on asphalt. What bravo said with the degreaser didn't do a lot (tried 2 different types), I mean when you hose it off you get rainbows but no matter how much you do it theres always some left :|
Keen to see how you get on. I might try some baking soda
I got some acid from Mitre 10, nasty sh*t. She said to water it down, though I didnt and it ate holes into the concrete :/
Dont use spirits of salt (which is that acid). Brake cleaner should get it off if its fresh?
30 seconds is for Moss mildew etc. CLR oil remover will work also.
Break cleaner does work if you get in quick..
I am going to have to paint my entire garage floor this summer. Love my E30 :angry:
Haha yeah, it was spirits of salt... They recomended it. It tuned the nice smooth concrete into rough crappy sandy stuff.
Spirits of salt = Hydrochloric acid. Wont help oil stains.
Sunshine is the best thing Mike. Takes time unfortunately.
It did get rid of it, but it did that by taking off the top layer of concrete :P
I've tried degreaser before without much luck, 'spose it wont hurt to give the oven cleaner a go. Otherwise time and the elements it is.
cheers guys
edit: just been told the landlord is down tomorrow, great.
Edited by Mike
