caleb 0 Report post Posted December 2, 2008 (edited) Which grade of petrol do you normally use for E46 2002 Jap Import The owner's manual written in Jap says 95 ron. Wonder if most people use 95 ron or the most economical grade i.e. 91 ron Edited December 2, 2008 by lufu Quote Share this post Link to post Share on other sites
Guest SamSpargo Report post Posted December 2, 2008 The highest grade at whichever mobil i'm at. Quote Share this post Link to post Share on other sites
mr E34 11 Report post Posted December 2, 2008 If it says 95, use 95 or 98.....why ask dopey questions. Quote Share this post Link to post Share on other sites
greenday-rulz21 6 Report post Posted December 2, 2008 (edited) You should always use the highest octane available, like 98 or 95. The last couple times I have filled up with 91 and it still has run smooth. There is a difference though. As the ignition system retards the timing to prevent preignition and so it doesn't damage the engine. It will still run fine but the chance of damage to your engine is far more likely. Lower octane increases fuel consumption (not more economical), higher octane should reduce fuel consumption. Edited December 2, 2008 by Nick021 Quote Share this post Link to post Share on other sites
Avenged.SSE 0 Report post Posted December 2, 2008 Who cares about economy anyway, petrol is cheap as chips atm, if you can't afford to fork out cash for 95 or 98 as cheap as it is now, then perhaps a cheaper choice of car is in order? Quote Share this post Link to post Share on other sites
Apex 693 Report post Posted December 2, 2008 95 for me, Shell has Flybuys. 98 if its a Turbo im driving. Quote Share this post Link to post Share on other sites
tire 10 Report post Posted December 2, 2008 You should always use the highest octane available, like 98 or 95. The last couple times I have filled up with 91 and it still has run smooth. There is a difference though. As the ignition system retards the timing to prevent preignition and so it doesn't damage the engine. It will still run fine but the chance of damage to your engine is far more likely. Lower octane increases fuel consumption (not more economical), higher octane should reduce fuel consumption. I believe this is not the case for the M10 engine as it is lower compression. I remember reading in one of my pieces of bmw literature for my car that only 91 should be used (m10b18 e30). Quote Share this post Link to post Share on other sites
greenday-rulz21 6 Report post Posted December 2, 2008 I believe this is not the case for the M10 engine as it is lower compression. I remember reading in one of my pieces of bmw literature for my car that only 91 should be used (m10b18 e30).I am talking about more modern engines like in the e46. The older engines this might not apply to as back then the octanes probably weren't as high. Quote Share this post Link to post Share on other sites
tire 10 Report post Posted December 2, 2008 I am talking about more modern engines like in the e46. The older engines this might not apply to as back then the octanes probably weren't as high. Absolutely Quote Share this post Link to post Share on other sites
JiB 2 Report post Posted December 2, 2008 We get 100km's more out of 98 in the E46 than from 91. I can't really tell the difference between 95/98 for the E30, but hey, if 98 reduces the chances of detonation then I don't see why I should "save" 2c per litre if it means my motor lasts longer. So it seems that 98 is more economical? For a 325e30's and 328e46's anyway. Quote Share this post Link to post Share on other sites
my_e36 43 Report post Posted December 2, 2008 I always use 95 for all my cars regardless of age, model and make. Modern engines are capable to make adjustments to take advantage of it. Older cars use 95 certainly won't hurt and the exhaust pipes are noticibly cleaner (less soot). Using 95 can do more milage than using 91, and it's more than enough to make up the price differnce (and some). Also, petrol in Japan are 94-98 octane for regular (depend on brand and where you are in Japan) and 100 for premium. Given the choices availabe in NZ, you should really use 95 at least for a Jap import. Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted December 2, 2008 Anything with a CR approaching 10:1 (Most petrol-powered BMW cars) should use 95 or higher to prevent detonation. Quote Share this post Link to post Share on other sites
jjs 64 Report post Posted December 2, 2008 98 all the way Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted December 2, 2008 Will definitely be using 98 when car is done, may even dabble in some octane booster for track days haha Quote Share this post Link to post Share on other sites
e30plz 1 Report post Posted December 2, 2008 98 in a 316i? Ruthless Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted December 2, 2008 98 in a 316i? Ruthless Gota make up some of the difference somehow Quote Share this post Link to post Share on other sites
Andre3000 55 Report post Posted December 4, 2008 Always Bp ultimate for me, or the good caltex if theres no bp around. i find nothing beats flooring it in 2nd with a full tank of ultimate behind the pedal Quote Share this post Link to post Share on other sites
huff3r 347 Report post Posted December 4, 2008 I alwayz use the 95 at caltex (dad works for chevron lol), but i found other brands of petrol tended to ruin my mileage figures anyway.... haven't tried BP Ultimate yet, might be worth a go... Quote Share this post Link to post Share on other sites
joshnz 2 Report post Posted December 4, 2008 Been loyal to Shell for years, V-power is good. Quote Share this post Link to post Share on other sites
pjay 8 Report post Posted December 4, 2008 Shell. I got 10 free movie tickets with my flybuys. The bitches like free movies Quote Share this post Link to post Share on other sites
simke 0 Report post Posted December 5, 2008 98 at BP, been using it in my old Mitsi as well ever since they started selling it. Quote Share this post Link to post Share on other sites
E46-RAT 1 Report post Posted December 6, 2008 I run all my cars on BP 98,and they love it. But the price was a bit of a killer a while back! Quote Share this post Link to post Share on other sites
lbirgel 0 Report post Posted December 6, 2008 Now that I’ve moved house i use 98 because bp is closer. used to use 95 at shell or gull. can’t say I noticed any difference between the 98 and 95 tho. Also any one used that octane booster stuff? Does it make a difference in performance and does it actually clean the engine? Quote Share this post Link to post Share on other sites
Apex Effects 3 Report post Posted December 8, 2008 hehe octane booster its a funny little thing. my old 89 325(Nz New) loved it. from Tauranga to wellington(hutt valley) on 3/4 of a tank of 98 plus a bottle of whines race octane booster. if label is close to correct i was running bout 102 octane(badness) o i forgot to mention i wasn't nanering it. minimum 130 on straights the occasional 190kph blitz(not that i say its a sensible thing to do on public roads) so 500kms hard driven an only using bout 45 liters of gas sounds good to me. i run minimum of 95 in my Nissan would prefer 98 just for the sake of it. Quote Share this post Link to post Share on other sites
huff3r 347 Report post Posted December 8, 2008 I used to run octane boost in my telstar because it needed all the help it could get and it definitely made a difference.... much cleaner and far more mileage, that was using the STP Octane Boost, which is apparently about 7 numbers RON Quote Share this post Link to post Share on other sites
