OLLIE 27 Report post Posted January 29, 2009 E36 318is - M44 Purchased the car, all the air con was hooked up but the belt was missing. hooked up a new belt. Air con isn't working looking closely at the air-con pump it doesn't look like the internals are spinning, but that may just be my misjudgment. the air con light on the control panel comes on but perhaps it doesn't trigger the pump to engage?? How do i go about trouble shooting this and getting the air con up and running! damn it is hot!! Quote Share this post Link to post Share on other sites
Izako 0 Report post Posted January 29, 2009 E36 318is - M44 Purchased the car, all the air con was hooked up but the belt was missing. hooked up a new belt. Air con isn't working looking closely at the air-con pump it doesn't look like the internals are spinning, but that may just be my misjudgment. the air con light on the control panel comes on but perhaps it doesn't trigger the pump to engage?? How do i go about trouble shooting this and getting the air con up and running! damn it is hot!! Silly question but have you check your fuses? Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted January 29, 2009 Silly question but have you check your fuses?yeah check fuses , that's about all I've done. Could it be missing a relay? Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted January 29, 2009 yeah check fuses , that's about all I've done. Could it be missing a relay?if the ac gas is low or leaked out then the compressor wont turn on .might be stuffed clutch or leaky air con panels inside or outside . i have bits if needed. cheers brent 021433600 Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 29, 2009 (edited) Theres a pressure switch on the receiver dryer, if the gas pressure is low due to leaks, it wont switch on as Brent said. Get it checked by an air con specialist Ollie BTW..dont by pass the pressure switch...youll end up damaging the compressor Edited January 29, 2009 by *Glenn* Quote Share this post Link to post Share on other sites
HELLBM 1674 Report post Posted January 29, 2009 Give me a call. Easy fix.. Quote Share this post Link to post Share on other sites
