Andre3000 55 Report post Posted February 5, 2009 First appeared round a month or two ago, expected it to be worn brake pad and took it to glenn's for service/brake pads. Brake pads had plenty of meat on them and i can see anything out of the ordinary on inspection, but they are aftermarket pads (thats what Glenn said). Its starting to really annoy me, help please? Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted February 6, 2009 change your pads. I'd put money on it being the brake pads, worn or not. Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted February 6, 2009 Could be the rotors, Or calipers making contact with the rotors. Quote Share this post Link to post Share on other sites
Andre3000 55 Report post Posted February 6, 2009 It happens more under light braking at low speeds Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 6, 2009 Andrew... as I said... to get rid of the noise...machine the rotors and fit OEM disc pads Quote Share this post Link to post Share on other sites
matt45 1 Report post Posted February 6, 2009 had exactly the same problem .... previous owner had just fitted aftermarket pads and was really noisy, had the pads and rotors changed for oem (rotors done coz they were gettin abit on the old side), and it instantly fixed the noise. Quote Share this post Link to post Share on other sites
Avenged.SSE 0 Report post Posted February 6, 2009 Just outta curiosity, how much would this cost for an E39? I'm having the same problem with mine and it's getting realllly annoying! Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 6, 2009 Just outta curiosity, how much would this cost for an E39? I'm having the same problem with mine and it's getting realllly annoying! Machine the rotors and fit OEM pads $250 +Gst retail for the front, if it needs new rotors approx another $260 + Gst Could give you a better price on Monday Quote Share this post Link to post Share on other sites
lbirgel 0 Report post Posted February 6, 2009 Glenn. how much you recon for new oem rotors and oem pads for the 30. im not sure if my rotors are aftermarket but i know my pads are. cheers Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 6, 2009 Glenn. how much you recon for new oem rotors and oem pads for the 30. im not sure if my rotors are aftermarket but i know my pads are. cheers I'll price them on monday for you Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted February 6, 2009 OEM pads are the only way forward for the e30..everything else squeaks! Quote Share this post Link to post Share on other sites
Katalyst 0 Report post Posted February 6, 2009 just bought a set of these zimmerman sport crossed drilled & slotted rotors and a set of oem pads from BM Workshop for $280 inc freight!! Quote Share this post Link to post Share on other sites
greenday-rulz21 6 Report post Posted February 6, 2009 just bought a set of these zimmerman sport crossed drilled & slotted rotors and a set of oem pads from BM Workshop for $280 inc freight!! Jeez! That is super cheap. Quote Share this post Link to post Share on other sites
Katalyst 0 Report post Posted February 6, 2009 yeah mate!!! dont know weather it was my sexy voice or not, but she said she had a surplus of those rotors and gave them to me at the same price as the oem replacements Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3043 Report post Posted February 6, 2009 First appeared round a month or two ago, expected it to be worn brake pad and took it to glenn's for service/brake pads. Brake pads had plenty of meat on them and i can see anything out of the ordinary on inspection, but they are aftermarket pads (thats what Glenn said). Its starting to really annoy me, help please?FWIW My magic solution to squeaky disc brakes?Good old fashioned copper grease, a light film on the back of the pad where it sits on the piston, quietens down even the worst in my experience. Plus makes it easier to get pads in and out. Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted February 6, 2009 oem rotors are the safe option but there are some good aftermarket ones around. I use znoelli slotted rotors in the race car and they have been pretty good, i'd recommend them, they are cheap too. ($60 ea from BNT). For a standard E30 there is no need to spend any more than that on rotors. It's the pads that you have to get right, OEM is the only option IMO, unless you use an expensive aftermarket pad, and even sometimes they squeal. Ferodo Excels aren't to bad and are cheap .... just some thoughts Quote Share this post Link to post Share on other sites
lidistick 70 Report post Posted February 7, 2009 My pads squeal like a virgin. Dust like mad too. Total confidence in braking hard repeatedly. Hawk HP+ pads and currently Brembo slotted rotors. Yet to fit the Znoelli rotors Quote Share this post Link to post Share on other sites
laadeelaa 0 Report post Posted February 8, 2009 Just outta curiosity, how much would this cost for an E39? I'm having the same problem with mine and it's getting realllly annoying! I share your embarrassment too. Ugh. Wish uncle Glenn lived up the raod. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 8, 2009 I share your embarrassment too. Ugh. Wish uncle Glenn lived up the raod. I do... its a long road though Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 8, 2009 Just outta curiosity, how much would this cost for an E39? I'm having the same problem with mine and it's getting realllly annoying! Depends on chassis # there are 3 different options The most common are: Rotors $170 incl....Pads $146 Incl Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 8, 2009 Glenn. how much you recon for new oem rotors and oem pads for the 30. im not sure if my rotors are aftermarket but i know my pads are. cheers I can do the Zimmerman vented, slotted, drilled sports rotors for $130 each incl. OEM pads for $100incl and OEM rotors for $110 incl. These prices are for vented rotors only Quote Share this post Link to post Share on other sites
lbirgel 0 Report post Posted February 8, 2009 I can do the Zimmerman vented, slotted, drilled sports rotors for $130 each incl. OEM pads for $100incl and OEM rotors for $110 incl. These prices are for vented rotors only cool! will be one of the things i get onto next! Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 8, 2009 cool! will be one of the things i get onto next! Only 2 sets of Zimmerman rotors at that price after that the price goes up to probably more than 30% Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 8, 2009 Only 2 sets of Zimmerman rotors at that price after that the price goes up to probably more than 30% All sold Quote Share this post Link to post Share on other sites
Andre3000 55 Report post Posted February 17, 2009 FWIW My magic solution to squeaky disc brakes? Good old fashioned copper grease, a light film on the back of the pad where it sits on the piston, quietens down even the worst in my experience. Plus makes it easier to get pads in and out. How is that supposed to work? I'll give it a try tomorrow and see. Quote Share this post Link to post Share on other sites
