bravo 35 Report post Posted March 11, 2009 Where can I buy exhaust heat wrap? What to wrap my intercooler piping. Quote Share this post Link to post Share on other sites
pjay 8 Report post Posted March 11, 2009 http://www.trademe.co.nz/Browse/SearchResu...amp;type=Search Quote Share this post Link to post Share on other sites
Jono51 61 Report post Posted March 12, 2009 Repco Quote Share this post Link to post Share on other sites
Boost Junky 1 Report post Posted March 12, 2009 Sedgedins do like 50ft for around $35 thats the 1" wide by 50ft long they also do 2" wide by 50ft long for like $52. https://www4.eaccounts.co.nz/eOrder_v1.asp?...stRecnum=144947 https://www4.eaccounts.co.nz/eOrder_v1.asp?sListRecnum=19356 Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted March 12, 2009 Cheers. I'll check at Ripco, but if its not super cheap, I'll hit up Segedins - at least their product is likely to be good. Quote Share this post Link to post Share on other sites
3series 0 Report post Posted March 12, 2009 hey Graham, make sure you get some fixings at the same time. Not all wraps include this. Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted March 12, 2009 Cheers Andy, I plan to. Could always "Race Tie" it! Quote Share this post Link to post Share on other sites
smiddy 76 Report post Posted March 12, 2009 Forman insulation! They have it all. Quote Share this post Link to post Share on other sites
Julian@Racetech 0 Report post Posted March 12, 2009 Where can I buy exhaust heat wrap? What to wrap my intercooler piping. Here. Racetech Quote Share this post Link to post Share on other sites
huff3r 347 Report post Posted March 13, 2009 We sell it at supercheap... when we have some in stock, but it doesn't come with any way of attaching it... i think its 2inch by 50ft, and around $50 maybe? Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted March 15, 2009 could you get it HPC coated? Quote Share this post Link to post Share on other sites
Boost Junky 1 Report post Posted March 17, 2009 could you get it HPC coated? Wouldnt keep the heat out man Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted March 17, 2009 Why wouldn't it? Surely it would work the same as it does when you get your exhaust manifold, turbo housing, head chambers done? Quote Share this post Link to post Share on other sites
Boost Junky 1 Report post Posted March 17, 2009 I thought HPC coating was simply a method of coating for example exhaust systems i.e. the process of baking the paint on which in turn has a much more durable coat which wont chip, flake or burn off? Quote Share this post Link to post Share on other sites
smiddy 76 Report post Posted March 17, 2009 You need fibreglassed cloth with foil attached. This can be bought in sheets. You need to stop radiant heat from reaching your cool charge air. Cloth can be cut into strips wraped onto pipes then alli taped on. looks good works well. Foreman insulation. Quote Share this post Link to post Share on other sites
westy 614 Report post Posted March 17, 2009 I thought HPC coating was simply a method of coating for example exhaust systems i.e. the process of baking the paint on which in turn has a much more durable coat which wont chip, flake or burn off? Tis also an insulator. Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted March 17, 2009 Marty's had his done, and I think he said it was about a 40% heat retention with the HPC? Quote Share this post Link to post Share on other sites
smiddy 76 Report post Posted March 17, 2009 Marty's had his done, and I think he said it was about a 40% heat retention with the HPC? He needs to retain cold air not hot air! Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted March 17, 2009 I got some heat wrap. Will let you all know how I think its going once the car is running again. Hopefully updating my project thread in the next day or so - waiting on some parts (bolts and seals) and getting a tool machined. Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted March 17, 2009 Marty's had his done, and I think he said it was about a 40% heat retention with the HPC? My understanding is that proper HPC coatings not powder coatings apply a ceramic layer to the surface of the object being coated.  As the ceramic can be used as an insulator wouldn't it suit the purpose? I know they use cermic tiles on the bottom and leading edges of the space shuttles to protect the shuttle from the heat of re-entry. If you had the inside and exterior of the pipe coated you would have two layers of insulation: 1) internally preventing heating of the air from the alloy pipe and 2) externally preventing heating of the alloy pipe from engine bay temps. Bravo: didn't mean to question what your doing just wondering if it might be a better option, interms of functionality and time/hassle... Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted March 17, 2009 Yeah mate. Never even crossed my mind. I like the discussion - its useful for a change . Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted March 17, 2009 (edited) http://hpcoatings.co.nz/turbos.htm Taken from the website: Intercooler Pipes Coating intercooler pipes, inside and outside, will make them look great in your engine bay. The HiPerCoat coating will stop rust from forming on the inside or outside and will keep the cooled air charge cooler. Edited March 17, 2009 by DRTDVL Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted March 17, 2009 They do some cool stuff - I like the idea of chromed headers that won't discolour, and have better thermal properties as well! Pity I probably can't justify the expense. $40-80 of heat wrap, although not as pretty is more my budget. It's not exactly a show car. Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted March 17, 2009 Had a look as well, and just got my new headers for the E28 today, so guess I may pay them a visit I think. Quote Share this post Link to post Share on other sites
Driftit 2248 Report post Posted March 17, 2009 Had a look as well, and just got my new headers for the E28 today, so guess I may pay them a visit I think. Have a look at mine of Friday Dave. A few mates have had their turbos coated. Works a treat. Looks alot better than heat wrap. Heat wrap gets all manky pretty quickly. But wrapping or coating will give you similar results. Quote Share this post Link to post Share on other sites
