2quik4u
318 is performance questions
I am from costa rica we have a high speed track here that is where it happened any ways do the bmw have a cut off switch ? do they top out and then cut off ?
Watch out NASCAR!
Edited by Mattzy
Jimmy
What brand of electric supercharger were you running and where can i buy one?
Id definitely be keen just to bolt one on my 320... That will be insane! Id get to 250kph no problem!
Also do they make them for '89 GL corollas? could stick one on my sisters auto thing!
cheers :ph34r:
Refer to links posted, All those are tried and tested by real professionals.
My mates '89 Gl Corolla is running 2 Boost Bars and does 8 second passes.
He might even come along to the meet at Meremere if/when it happens.
Edited by E30ONP
Yup have done that and thinking about placing an order tomoro.
Wow are you sure is a GL then? Ours is a hatchback so may be a lil slower, we will see on the day.
Its auto so she should be algood on the launches, No stalls or bunny hops etc.
Oh, his is a sedan, but hers being a hatch it should be lighter.
And with perfect launches (Slapping from N to D at 5k) she may be able to make it into the 7 second club.
Good luck.
Edited by E30ONP
James - you do this. I know this. :ph34r:
Huh? The guy said 1997 318iS, Wouldn't that make it an E36..? With an M42..?
Im glad someone knows his cars not like mr pulp fiction
*jumps on bandwagon*
Rules and regulations of the road:
Please review the following summary of Costa Rica's traffic laws. Obey these regulations at all times. Avoid accidents by driving carefully and defensively, that is, expecting the unexpected.
1. Unless otherwise indicated, minimum speed on highways is 40 kilometers per hour (k.p.h.). The speed limit varies and is posted by the road.
2. On highways and secondary roads the speed limit is 60 k.p.h., unless otherwise indicated.
3. In urban areas, the speed limit is 40 k.p.h., unless otherwise indicated.
4. Around school zones and in front of hospitals and clinics the speed limit is 25 k.p.h.
Some drivers here are reckless and rude, especially in a major city. Although the speed limit is usually 40 k.p.hh, Costa Rica holds the world's highest auto fatality rate (18 deaths per 100,000 kms., as opposed to 2.7 deaths in the U.S.)
And i'm the only one that picked up on that? What the hell..
Yeah those electric superchargers.. Had my 316i hitting 228kph.
I'd post up my dyno sheet but, I lost it. 284rwhp on low boost.
Can you please tell me where I can buy one of these ? I should do it as well, while I'm waiting for my flywheel :P
Glenn, just bolt several of these on, and your car will go SO fast, you'll be able to meet this guy in costa rica in person!
All over eBay. You'll be amazed at what a girly car is really capable of with forced induction.
Are these legal in the race series? Anyone know?
Dont know to be honest........might want to check the rule handbook :D
I might just run an invertor and use the new hairdryer I just bought. Think I'll tee it into the induction piping and switch it from the TPI switch through a relay.
Sounds like you have it sussed Glenn.
Just remove the tread from those tyres of yours with a sharp knife,
And your new slicks should be handle the extra power.
anyway back to the original topic
yes you can make your SMALL motor a bit faster but will loose realiability
you can do what i did e30 325i < e36 m3
or you can repower it
im installing a 1uz quadcam v8 into an old hilux and would recomend it to anyone
its been done before to a purple 318ti
your wallets the limit.
jeremy
