tire 10 Report post Posted May 14, 2009 Hey, what size sockets/bits do I need to loosen the drain and fill plugs on the manual gearbox in my 89 318i? I'm asking cause I don't have any hex head bits so I will need to buy the right ones. Also, is it the same for g260s? Cheers. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 14, 2009 17mm Quote Share this post Link to post Share on other sites
|ncary 0 Report post Posted May 14, 2009 You need a short 17mm allen socket, Powerbuilt make a special one just for BMW's, if you get a standard long one it won't fit between the gearbox and the tranny tunnel and you'll waste about 30 bucks (Ask how I know that..) Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 14, 2009 You need a short 17mm allen socket, Powerbuilt make a special one just for BMW's, if you get a standard long one it won't fit between the gearbox and the tranny tunnel and you'll waste about 30 bucks (Ask how I know that..) If you get the longer one it has more uses and you just use a 17mm ring spanner on it Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted May 14, 2009 I realized that too when i got a std one so had spend a few mins with the hacksaw Quote Share this post Link to post Share on other sites
Jamez 2147483647 Report post Posted May 14, 2009 ^^^ haha i had the same thing happen to me. Quote Share this post Link to post Share on other sites
melowpuf 19 Report post Posted May 14, 2009 (edited) If you get the longer one it has more uses and you just use a 17mm ring spanner on it Eagle Posted Today, 01:31 PM I realized that too when i got a std one so had spend a few mins with the hacksaw Jamez Posted Today, 01:46 PM ^^^ haha i had the same thing happen to me. Haha Square peg.. square hole Edited May 14, 2009 by melowpuf Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 14, 2009 Haha Square peg.. square hole Yeah... I agree Lance... some of these guys can't think outside the square Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted May 14, 2009 Its all good, i just make myself a special gearbox plug tool Quote Share this post Link to post Share on other sites
|ncary 0 Report post Posted May 14, 2009 I don't know where else there is a 17mm allen hole in existance! So the 10 dollar proper bit for a ratchet works well Anyone want a full sized 17mm allen bit? Free. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 14, 2009 I don't know where else there is a 17mm allen hole in existance! So the 10 dollar proper bit for a ratchet works well Anyone want a full sized 17mm allen bit? Free. When you graduate up to an E36 or E39 you will need one to check your Auto Trans fluid Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted May 15, 2009 i use a 17mm wheel bolt with 2 nuts locked onto it Quote Share this post Link to post Share on other sites
mark247 42 Report post Posted May 15, 2009 You need a short 17mm allen socket, Powerbuilt make a special one just for BMW's, if you get a standard long one it won't fit between the gearbox and the tranny tunnel and you'll waste about 30 bucks (Ask how I know that..) I found that out the hard way as well. If you loosen the gearbox mounts and drop the gearbox a bit I think you can get it in there. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 15, 2009 I found that out the hard way as well. If you loosen the gearbox mounts and drop the gearbox a bit I think you can get it in there. Then the level wont be accurate....it will be overfull depending on how far you drop it....especially if you jack it up in the front to check it Quote Share this post Link to post Share on other sites
tire 10 Report post Posted May 15, 2009 Hey thanks Glenn. I bet people have some interesting tools / experiences to share with regard to getting the fluid in the fill hole? Quote Share this post Link to post Share on other sites
mark247 42 Report post Posted May 15, 2009 Hey thanks Glenn. I bet people have some interesting tools / experiences to share with regard to getting the fluid in the fill hole? I just used the tube that came on the end of the ATF bottle and squeezed it in no probs Quote Share this post Link to post Share on other sites
