DRTDVL 0 Report post Posted July 19, 2009 ya i've contemplated that also. we have increased the throw and the syncro's are doing good so far... We can look at it again once the throw is less vague... its gotten worse since i've increased the throw... i can't find 3rd! Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted July 26, 2009 Righto... Mister MLM has had a play with my spare leaver for the gearbox and has used some bronze pillow bushes to help get rid of the slop in the leaver... Hopefully this will allow me to find third gear...!!!!!!!! Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted August 5, 2009 for a giggle... Satin Black bumper spray... Note: Tyres with rim protectors are a bitch to mask off... Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted August 6, 2009 Put the painted wheels on tonight.... Quote Share this post Link to post Share on other sites
Guest Simon* Report post Posted August 6, 2009 They don't look awful Heath Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted August 6, 2009 wait till you see my other wheels... and how the caliper sits in the spokes Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted August 7, 2009 Results from todays Dyno Run. Will get the video soon... Peak Power = 100.2Kw @ 7200 rpm = Rev Limiter Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted August 8, 2009 Mint - that's at the wheels right? Good power! Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted August 9, 2009 Mint - that's at the wheels right? Good power! So once i get the rev limit extended anouther 300rpm it should be rather interesting to see what it does... Quote Share this post Link to post Share on other sites
kingkarl 136 Report post Posted August 9, 2009 that's a shitload of torque! Awesome. Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted August 9, 2009 I some how don't think its correct... Seams very very high for the car... Quote Share this post Link to post Share on other sites
JiB 2 Report post Posted August 9, 2009 I some how don't think its correct... Seams very very high for the car... From what I understand ATW figure is a different beast altogether from fly torque which is what we use to compare different cars with. Atw - is usually magnified by moment couples about the gears/diff/wheels For example, a lot of turbos have 1200nm atw, but are in fact in the 300-400nm at the fly. Regardless - your car has plenty of both tq and pwr from what I experienced Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted August 9, 2009 Regardless - your car has plenty of both tq and pwr from what I experienced 70.02 HP per Ltr (133.6 HP @ Wheels) the bimmers that where there: 93 E36 M3 = 74.96 HP per Ltr (224.1 HP @ Wheels) 95 E36 328i Coupe = 50.51 HP per Ltr (141.1 HP @ Wheels) 89 E30 320i Touring = 53.35 HP per Ltr (133.1 HP @ Wheels) 87 E30 325i = 48.33 HP per Ltr (120.5 HP @ Wheels) So i'm happy with the figures... should be really interesting once i get more rev's in the car Quote Share this post Link to post Share on other sites
westy 614 Report post Posted August 10, 2009 What gear was it run in? Saw on of the other plots floating around was run in 3rd gear, explains the high torque figure. Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted August 10, 2009 What gear was it run in? Saw on of the other plots floating around was run in 3rd gear, explains the high torque figure. Ya my sheet says 3rd gear also... i'm trying to work out how to use the final drive and gear ratio to get an idea of what it might be... not too fussed the curve looks good... wouldn't mind getting rid of that dip at 4k tho Quote Share this post Link to post Share on other sites
westy 614 Report post Posted August 10, 2009 Just stay above 5000 revs you'll be sweet. Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted August 10, 2009 Dyno Run Video - In HD! http://www.youtube.com/watch?v=iizaYP5gmeA Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted August 10, 2009 Looks good mate! Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted August 18, 2009 Went for a good drive last night... Car hooks up amazing out of the corners and had both wheels spinning out of a 2nd gear corner. Super nimble!!! changes direction soo soo nicely... The only problem was i was getting use to the car and decided 4th is too long now as 138ish in 3rd is very easy to get to.... I need more power i think also... car started to feel slow towards the end of the drive... currently has 135 hp @ wheels i think the new target will be a min of 160hp @ wheels... Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted August 31, 2009 Got the rev limit extension chip today in the mail... Have the dyno session booked in at Hi Velocity on Thrusday to make sure it doesn't to anything silly Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted September 3, 2009 2.7hp gain in power and more power over most of the rev range... But it looks like it's just about at peaked out now at the limiter... Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted September 3, 2009 That really is kinda cool the way its still pulling at the limiter! Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted September 3, 2009 Yup Yup... Cam if your bored next weekend and want to come play pit crew your more than welcome... So once the hydro lifters, Aftermarket ECU, MAP sensor, and ITB go in hehehe... and maybe 8000rpm it should be alot of fun... but then thats probably about 5+ grand away.. min... but it all will be done! Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted September 3, 2009 I so wish I could, but I can't It's the Fiat Club event, yes? They run a good event Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted September 3, 2009 (edited) Yup Fiat Club... Oh well next time then... I"ve signed up for the sainsbury road event also.. and will look at doing kemp road also next month... I've manage to score a trailer and dad's explorer so no driving down in the racecar for me... = less likely to get a ticket... Edited September 3, 2009 by DRTDVL Quote Share this post Link to post Share on other sites
