Palazzo 522 Report post Posted July 8, 2009 Had a look at an E36 coupe, the drivers door window drops as it should when the door opens and shuts again, but then at completely random times will open and close repeatedly. Only 5mm or so as it's supposed too, but noisy and annoying. Easy fix? Cheap? Expensive? Cheers. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted July 8, 2009 Could be channel slide clips, regulator, window guides or motor. Coupe doors give alot of problems with there windows. Needs checking properly Quote Share this post Link to post Share on other sites
Palazzo 522 Report post Posted July 8, 2009 Could be channel slide clips, regulator, window guides or motor. Coupe doors give alot of problems with there windows. Needs checking properlyThanks Glenn, will keep that in mind. Assume if I allow $3-400 it should be enough? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted July 8, 2009 (edited) Thanks Glenn, will keep that in mind. Assume if I allow $3-400 it should be enough? Not likely... depends whats rong Edited July 8, 2009 by *Glenn* Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted July 8, 2009 Sounds like a micro-switch fault? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted July 8, 2009 Sounds like a micro-switch fault?Could be that as well...but he also said it was noisey Quote Share this post Link to post Share on other sites
Palazzo 522 Report post Posted July 8, 2009 To clarify, it's just the noise of the window going up and down repeatedly, no strange grinding noises or anything like that, just an electrical whir as it goes up and down. Over and over and over. . . . . . . . Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted July 10, 2009 will be the micro switch , common thing to wear out , the little plastic tiity wears down . just get a second hand one from less used left side . have some 021433600 Quote Share this post Link to post Share on other sites
