Forrest
Maddie - Road/Track E30
^ Leaking coolant = loose hose = easy fix
Electric window = no idea
Driveshaft = see my other thread in maintence,
Speedo = some idiot (i.e me) didn't put the plug on properly on the diff :wacko:
Washer fluid light = ultimate noob fail, forgot to fill the reservior up lol
So just the electric window is beyond me, everything else is just me being in a rush to refit everything.
It's just a tempremental e30 Dan, I am sure you know what those are like :rolleyes:
Just had this myself, in the end it was simply the connections in the switch that were completely covered in crap. A quick clean and brush and they were good as gold again.
I assume youve tried this already though ?
^ One side works, swapped the switches and didn't make a difference. I will clean everything and see what I can do. Cheers, Martyn
Have you tried putting power straight to the motor? To rule out the motor is stuffed?
^ Not yet, that is the next plan, more worried about my driveline issues atm. Cheers tho
Nice work Nath, be keen to see her in person some time! I don't know if you've nailed the sleeper look tho, looks pretty badass imho :ph34r:
noob q but, how do you do this as i need to check mine.
Car battery and 2 wires :D
Yep pretty much. One way it'll go up. Other way it'll go down.
K so car is getting power to the window switch, which means busted connection in door and or busted window motor.
And the bloody driveshaft is fixed...wooooooooooooo
Few bits to tidy and a rear sway bar to fit and its done done done :D :D :D
Mint, so done by friday for sure? I should be rolling in the subaru :o
^ I will be there on friday, euro'd, slammed, race'd and rollin. Ha
Most likely corroded connections in the plug where the door loom goes to the car body. Rubber seal failed or whatever.
Lunchtime teasers.
There are no words, apart from I am bloody stoked! :D
Brief two min run around the block.
Points to note.
- Car sounds tits.
- LSD locks up far far far better with a urethane diff mount + new redline fluid.
- Brake pads slightly rub on wheels, will go for a drive after giving it a clean and rub the edges off the new pads.
- Now time to commence suspension set up testing.
- Wheel alignment tomorrow.
Enjoy friends.
looks awesome Nath.
Black europlates??
I can't come see it at the meet this Friday, but I'd love to check it out and go for a ride in it some other time soon.
Edited by deane30
Looks badass apart from the eyelids that make it look dopey - sorry
+1, Maybe look better if they were painted black. Looks mint anyway bro, Nice.
Legend.... Looks awesome Nath - will be good to see it on Friday. Twin pipes out back to finish her off i reckon!
^ Nah this exhaust will never be touched, it sounds like utter sex.
Yup see you Friday.
FYI Simon etc, I took the eyelids off and it looks heaps better, was worth a try though.
Pictures to come :) Except one of my mirrors fell out of the holder and broke <_< so hopefully sort one before friday.
Just drove 60km and I am in love again, fantastic noise, handles amazing, looks amazing, now to keep this one square :rolleyes:
Should give the eyelids a spray with some black just to see, I reckon they'd look better. Spray the volvo lip too.
^ I would sell em, but they got cracked when couriered to me <_<
bad? There glass aye? I'm doing some glassing at tech at the moment so might be able to fix them up...
