Guest Simon* Report post Posted October 20, 2009 Hi I'm wanting to re-stick some of the clips that have pulled away from my front doorcards. What glue would you recommend using, just A2 or similar? Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted October 20, 2009 i have used that black (sort of like silicon) stuff they use for windscreens , sticks to most things, has a good amount of give in it . takes a while to set though , but seams to hold better than most hard glues or f2 type glues etc . panel beaters tend to use it every where to stick panels and body kits on etc . Quote Share this post Link to post Share on other sites
Mark 178 Report post Posted October 20, 2009 Do you want to glue up busted clips? Prob better to buy new clips from BMW... Unless they're outrageously expensive of course. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted October 20, 2009 Hi I'm wanting to re-stick some of the clips that have pulled away from my front doorcards. What glue would you recommend using, just A2 or similar? We use a heavy duty hot glue gun and only use Wurth glue sticks for the plastic mounts that hold the clips. Quote Share this post Link to post Share on other sites
Guest Simon* Report post Posted October 20, 2009 Do you want to glue up busted clips? Prob better to buy new clips from BMW... Unless they're outrageously expensive of course. No they're not broken just need to reattach the plastic ones to the inside of the door card Cheers Glenn - hot glue gun sounds like the answer Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted October 21, 2009 i need to do the same also anyone got any ideas for gluing the door vinyl back on to the door card? I tried Ados F2 contact adhesive but it peeled off after a couple of weeks Quote Share this post Link to post Share on other sites
greenday-rulz21 6 Report post Posted October 21, 2009 I used the Ados F2 contact adhesive as Ollie mentioned to do exactly as you describe you want to do Simon. They turned out perfectly and hold extremely strong. 5 minutes after I stuck them together I could hold a clip and let the door card hang. Very strong. Still holding strong today. Ollie, I don't know how you did it but you're meant to apply the adhesive on both surfaces and let it get tacky before you put them together. Only half of the strip that I needed to stick back was loose so I ripped it fully off so I could get perfect coverage of the whole thing. If the adhesive wasn't applied to both surfaces or it was stuck together right away then it won't have a strong bond and won't last for long. The Ados stuff is only $10 a tube from memory and I've still got 1/2 left. Great stuff IMO if you use it right. Hope that's of some help mate. Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted October 21, 2009 cheers Nick. i did rush it so will give it another proper go. Ive used the stuff heaps and never really had a problem, perhaps my big can of it is a bit old ... Quote Share this post Link to post Share on other sites
Yuen 16 Report post Posted October 22, 2009 I used epoxy glue (Selley's Araldite) for exactly what you want to do Simon. Figured that stuff is stronger than Ados F2. While it's more expensive, you don't need that much. To me it was well worth the peace of mind knowing I wouldn't need to do it again. Having said that - got curious and searched for which would be more appropriate for door cards - see link. http://www.mr-dt.com/materials/adhesives.htm Reckon at the end of the day though, preparation is the most important thing. Quote Share this post Link to post Share on other sites
