pureboiracer 0 Report post Posted November 12, 2009 Hey guys, Hoping some guys will post up some pictures of there e30s and a mesurement from something like ground to chasis rail, just to give me and everyone else an idea of what height gives what look. Cheers Oli Quote Share this post Link to post Share on other sites
1rotty 40 Report post Posted November 12, 2009 Like this; Quote Share this post Link to post Share on other sites
Shady 0 Report post Posted November 12, 2009 (edited) Jamex springs. About 2" drop. Camera sitting on the ground. Some others have their even lower. I want to take mine down more, alot more. Will get a side shot with it on 14s if sunny tomorrow. Edited November 12, 2009 by Shady Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted November 12, 2009 (edited) Jamex Superlows. About 95mm front chassis, rear was legal however. Good amount of wheel tuck. Very much undriveable though, guard rub on most driveways needed to 'crab' hardout. Exhaust scrape on speed bumps ettc. Edited November 12, 2009 by e30ftw Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted November 12, 2009 More like, how low isn't your e30. stock springs, stock shocks. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 12, 2009 Jamex Superlows. About 95mm front chassis, rear was legal however. Good amount of wheel tuck. Very much undriveable though, guard rub on most driveways needed to 'crab' hardout. Exhaust scrape on speed bumps ettc. I think you might have a problem with your measuring instrument.... 95mm ??? Quote Share this post Link to post Share on other sites
mark247 42 Report post Posted November 12, 2009 90mm at the lowest point on the control arm i think on my e30 Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 12, 2009 The lowest point on any E30 or E36 in the front is at the chassis rail just behind the caster bush mounting point Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted November 12, 2009 Eibach 60mm fronts, 40mm rears with no rear spring pads. I am about bang on 100mm at the front chassis rail. Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted November 12, 2009 I think you might have a problem with your measuring instrument.... 95mm ??? Sorry, More specifically 95mm the lowest structural point.. Which yeah is those bracket bits for the Control arm bushes. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 12, 2009 Sorry, More specifically 95mm the lowest structural point.. Which yeah is those bracket bits for the Control arm bushes. It looks alot lower than that in the picture Quote Share this post Link to post Share on other sites
Matty104 0 Report post Posted November 12, 2009 65mm at sump guard, 80mm at control ar bush 95mm at front chassis rail on 18" wheels, pain in the ass if you just want to nip down to the shops real quick, Quote Share this post Link to post Share on other sites
Shady 0 Report post Posted November 12, 2009 90mm at the lowest point on the control arm i think on my e30 Say Hello, to Mr Pink Sticker or Failed WOF?! 65mm at sump guard, 80mm at control ar bush 95mm at front chassis rail on 18" wheels, pain in the ass if you just want to nip down to the shops real quick, As above. Howd you get away with those heights? My sump is just on 105mm (assume because one of the engine mount shocks are a bit you know what) otherwise heaps of clearence. Quote Share this post Link to post Share on other sites
diablo23 1 Report post Posted November 12, 2009 i doubt he'll get a pink sticker for only 5mm Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 12, 2009 i doubt he'll get a pink sticker for only 5mm You can... and you will get failed for 95mm by a LVI if hes doing his job properly as well. 100mm is the legal standard not 95mm Quote Share this post Link to post Share on other sites
diablo23 1 Report post Posted November 12, 2009 prolly on a rare occasion, i managed to survive long enough without gettin one Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 12, 2009 Survive does not = legal We should only be promoting legal modifications on the forum Quote Share this post Link to post Share on other sites
diablo23 1 Report post Posted November 12, 2009 well if hes that worried bout getting a sticker he should just get an lvv then Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 12, 2009 well if hes that worried bout getting a sticker he should just get an lvv then Correct.. mine is certed legaly at 75mm Quote Share this post Link to post Share on other sites
martyyn 2 Report post Posted November 12, 2009 Right now thats sorted.....back on topic people. Oli asked for photos of e30s and their suspension not a discussion on what people have gotten away with the last couple of years. No photo, no post ! Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted November 12, 2009 (edited) Eibach 35mm Lowered Front & rear I think the Sump was 120mm from the ground. ( sorry I don't know the other measurements ) And it still looked jacked up higher than my Hilux does currently Edited November 12, 2009 by Jimmy Quote Share this post Link to post Share on other sites
ED1RTY 2 Report post Posted November 12, 2009 (edited) I was running whiteline super lows all round and Boge turbo shortened shocks. Running 16" wheels with 205/40 rubber brought the Rear suspension crossmember mounts to 85mm off the ground and the lowest point in front was 90mm off the ground. I had been green stickered for that.. But when i went to LTNZ to get it taken off they passed as i still had a suffice amount of suspension travel and they deemed the car safe for use. Without a cert.. Soo i guess some people just don't do there jobs as well as they should. Although in saying that had a run bigger tyres or when the car was on 17" wheels the car was raised to 105 and 110mm respectively. Only pic i have with clearances Edited November 12, 2009 by KSMYRS Quote Share this post Link to post Share on other sites
Matty104 0 Report post Posted November 12, 2009 (edited) As above. Howd you get away with those heights? I'm just not silly about it, i don't go hooning around looking for trouble, i drive like its a sunday, had my days of being an idiot, now i just cruise. i just pick'd up some bilsteins for the front of my car and some new shock mounts so i'd say this will raise me a touch. edit:photo Edited November 12, 2009 by Matty104 Quote Share this post Link to post Share on other sites
diablo23 1 Report post Posted November 12, 2009 wow that looks mean chris : Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted November 12, 2009 Resize pls chris. 800x600 Quote Share this post Link to post Share on other sites
