Italiano_87 0 Report post Posted November 24, 2009 Getrag 240 is perfectly fine. I had one behind my 2.7 m20 stroker and it was fine, more power / torque than a standard m20b25. And even when it was turbo it held up fine. Don't think I have seen anyone have issues with a getrag 240, guys in the U.S are using them (from 318is) for m50 swaps etc, No issues.. guess i shouldnt worry bout the which gearbox i get then ae... just gona need a driveshaft that is from a facelift Quote Share this post Link to post Share on other sites
e30ftw 428 Report post Posted November 24, 2009 guess i shouldnt worry bout the which gearbox i get then ae... just gona need a driveshaft that is from a facelift Driveshafts are the same, pre FL and FL. Only difference is the hanger bearings, which can be swapped around... So if you have one from a pre F/L you would need to put a facelift type hanger bearing on it. Quote Share this post Link to post Share on other sites
Italiano_87 0 Report post Posted November 24, 2009 Driveshafts are the same, pre FL and FL. Only difference is the hanger bearings, which can be swapped around... So if you have one from a pre F/L you would need to put a facelift type hanger bearing on it. i dont have one as my car is auto at the mo lol but thanks Quote Share this post Link to post Share on other sites
e30ftw 428 Report post Posted November 24, 2009 All the driveshafts are 2 piece and have a hanger bearing / center support bearing in the middle. The auto / manual driveshafts are different yeah, but pre facelift and facelift are the same. You could even use the bearing on your auto driveshaft on the manual driveshaft if you happen to get yourself a a driveshaft from a pre facelift car. Just need to get it off carefully without ripping the rubber surround. Quote Share this post Link to post Share on other sites
Italiano_87 0 Report post Posted November 24, 2009 All the driveshafts are 2 piece and have a hanger bearing / center support bearing in the middle. The auto / manual driveshafts are different yeah, but pre facelift and facelift are the same. You could even use the bearing on your auto driveshaft on the manual driveshaft if you happen to get yourself a a driveshaft from a pre facelift car. Just need to get it off carefully without ripping the rubber surround. ohk cool but apart i tend to break things when im working on any of my cars haha... but driveshafts usually come with kits tho o hopefully i get the right one anyways Quote Share this post Link to post Share on other sites
Matty104 0 Report post Posted November 25, 2009 (edited) does kerry or mike from mosens not have one dude, if you go in and see them im sure they will sort you out with what you need. or send you in the right direction Edited November 25, 2009 by Matty104 Quote Share this post Link to post Share on other sites
Italiano_87 0 Report post Posted November 25, 2009 does kerry or mike from mosens not have one dude, if you go in and see them im sure they will sort you out with what you need. or send you in the right direction Yea jason found me one from mosens for $850 its the g240 kit... i just gota buy a new bearing a new gear knob and new master and slave cylinders... Quote Share this post Link to post Share on other sites
Matty104 0 Report post Posted November 26, 2009 (edited) sweet, bearing should be a 12x32x10 on a m20 from memory and you can get it from saeco on King street in frankton, cost around $10 Edited November 26, 2009 by Matty104 Quote Share this post Link to post Share on other sites
bmw_guy 0 Report post Posted November 26, 2009 Just make sure you get the right one haha Quote Share this post Link to post Share on other sites
Matty104 0 Report post Posted November 26, 2009 yea, just measure the spline to make sure, as brooks was a bit bigger, (first time hes ever been able to say that) Quote Share this post Link to post Share on other sites
oscar90 0 Report post Posted November 26, 2009 ^ LOL Quote Share this post Link to post Share on other sites
Italiano_87 0 Report post Posted November 26, 2009 Hey all i have found a complete conversion kit from Auckland $900 that is also including freight... im not phased if it is a 240 or a 260 as long as it gets converted... can always get a 260 another day. but thank you all for your help and much appreciated. Quote Share this post Link to post Share on other sites
Italiano_87 0 Report post Posted December 6, 2009 Hey does anyone know where to find dash mats? i have looked almost everywhere but cant find them Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted December 6, 2009 ebay. Or they come up on TM now and again and usually get snapped up pretty fast. Quote Share this post Link to post Share on other sites
Italiano_87 0 Report post Posted December 6, 2009 ebay. Or they come up on TM now and again and usually get snapped up pretty fast. Yea i bet they go pretty quick... they look real nice in cars... been looking round for over a month now but nothing Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 6, 2009 (edited) Don't think I have seen anyone have issues with a getrag 240, guys in the U.S are using them (from 318is) for m50 swaps etc, No issues.. The 318Is M42/M44 gearbox is a Getrag 250g the same stud pattern as M50/52 Thats what I'm using. The 240 can be used but mounting cross member and linkages need a mod because the gearbox ends up on an angle. Edited December 6, 2009 by *Glenn* Quote Share this post Link to post Share on other sites
oscar90 0 Report post Posted December 6, 2009 (edited) Supercheap auto can order then online from their australia shops, Don't know if they have E30's but they would be able to tell you quick enough. Don't think they are cheap though Edit: RE the Dash matts Edited December 6, 2009 by HT. Quote Share this post Link to post Share on other sites
Italiano_87 0 Report post Posted December 6, 2009 Supercheap auto can order then online from their australia shops, Don't know if they have E30's but they would be able to tell you quick enough. Don't think they are cheap though Edit: RE the Dash matts oh ok sweet as il ring them about it... thanks Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 6, 2009 (edited) There was also a place in Olive Road Penrose who sold them I bought one of them about 15 years ago for the wifes old E30. Zenetti (johno) might know who it is if they are still in business. I think it was Pioneer Distributors but I may be wrong. Re: Dash Mats Edited December 6, 2009 by *Glenn* Quote Share this post Link to post Share on other sites
Apex 693 Report post Posted December 6, 2009 Pioneer are still there, think they are in Chrch Street. Quote Share this post Link to post Share on other sites
