Italiano_87 0 Report post Posted December 8, 2009 can anyone please tell me the torque settings for the pressure plate bolts and the flywheel bolts for my 1988 320i E30 Bmw. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 8, 2009 (edited) Flywheel 98-112 Nm with sealant or blue loctite on the clean threads Clutch cover M6 24 Nm (6mm Bolts)..... M8 34Nm (8mm Bolts) Edited December 8, 2009 by *Glenn* Quote Share this post Link to post Share on other sites
sp8s 1 Report post Posted December 8, 2009 Jeeez your quick Glenn. 8 minutes I cant even get my Mechanic on the phone in less time than that. Quote Share this post Link to post Share on other sites
Italiano_87 0 Report post Posted December 8, 2009 Flywheel 98-112 Nm with sealant or blue loctite on the clean threads Clutch cover M6 24 Nm (6mm Bolts)..... M8 34Nm (8mm Bolts) that was pretty quick man... my engine is a m20... just converting my car to a manual Quote Share this post Link to post Share on other sites
Italiano_87 0 Report post Posted December 8, 2009 and is there meant to be a spigget bush in the flywheel? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 8, 2009 that was pretty quick man... my engine is a m20... just converting my car to a manual M6= 6mm bolts M8= 8mm bolts Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 8, 2009 and is there meant to be a spigget bush in the flywheel? Spigot bearing... try Brake & Trans...about $12 Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted December 8, 2009 He knows it's an m20. M6/M8 is the bolt size specification (6mm and 8mm shanks on the bolts respectively. Should be stamped into the bolt heads, otherwise measure.) Edit - damn you ARE fast Glenn, beat me by a hair! Quote Share this post Link to post Share on other sites
e30ftw 419 Report post Posted December 8, 2009 Make sure you have the bearing in there.. And you bang it all the way in, Some people just tap it in a little bit but it is meant to go all the way in (Get a socket that matches the outer race of the bearing and tap it in, don't force it in with the inner race). Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 8, 2009 The next question is probably going to be .....How do I line up the clutch plate With a clutch alignment tool or a screw driver...... you need a good eye to do that Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted December 8, 2009 M6= 6mm bolts M8= 8mm bolts we use to have fun with the new guys and drilling holes for m8 and m10 bolts... so many would drill a 8 or 10mm hole... then wonder why the bolt didn't properly. Quote Share this post Link to post Share on other sites
e30ftw 419 Report post Posted December 9, 2009 The next question is probably going to be .....How do I line up the clutch plate With a clutch alignment tool or a screw driver...... you need a good eye to do that I have always done mine by eye, Done it so many times I am pretty good at it lol. 1st time I used a plastic clutch alignment tool, They aren't that great to use. Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted December 9, 2009 I found the plastic one better than my $80 one! No effing about getting the right spigot and so on. I keep a plastic one in my tool box and glare at my expensive alignment tool hoping one day that I'll need to use it before it rusts. Edit: Actually I don't think it was $150... Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 9, 2009 If you have a lathe handy..you can whip one up using a piece of broom handle or dowel Quote Share this post Link to post Share on other sites
OLLIE 26 Report post Posted December 9, 2009 those plastic ones are very handy, eyeometer has always worked for me too though Quote Share this post Link to post Share on other sites
mark247 39 Report post Posted December 9, 2009 Plastic ones are good. I think they sometimes come with the clutch kit. Quote Share this post Link to post Share on other sites
