hybrid 1045 Report post Posted March 25, 2010 thats awesome ... would saved me hours! Quote Share this post Link to post Share on other sites
39KiwiTouring 2 Report post Posted March 25, 2010 Dishwasher saves using the old kerosine bath to wash parts, awesome job Rot this is real good to watch keep the posts coming. Quote Share this post Link to post Share on other sites
twisted 45 Report post Posted March 26, 2010 Mate, this is Awesome! Looks like i'll be trying to find an old dishwasher when i move too Quote Share this post Link to post Share on other sites
grantdavis28 8 Report post Posted March 26, 2010 The disassembled heater in my parts washer- just an old dishwasher really ^WIN Quote Share this post Link to post Share on other sites
[email protected] 0 Report post Posted March 26, 2010 What a good idea! Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted March 27, 2010 Heater has gone back together with its replacement motor. It won't be getting installed until the engine bay has be painted Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted March 27, 2010 Time for the motor and box to come out. But first I needed to clean up, the car was getting hard to work on Motor and suspension out Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted March 27, 2010 Just another photo of the new E36 mounting points Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted March 27, 2010 Some photos of the new engine mounts Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted March 27, 2010 I like the way the m44 looks with the twin carbs on it. I just wish it was a S14 Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted March 27, 2010 I got the first stage of the Jaycar programmable ignition working today. I still have to make something to switch the output for the wasted spark. Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted March 27, 2010 Are there any M44/M42 nuts on here It looks like the camshafts are adjustable- slotted holes behind the retaining bolts Is the socket doweled? If I undo the four bolts holding on the socket can I change the cam timing? Does anyone have a photo of the cam shaft encoder off a M42? Quote Share this post Link to post Share on other sites
e30guydownunder 2 Report post Posted March 28, 2010 (edited) Are there any M44/M42 nuts on here It looks like the camshafts are adjustable- slotted holes behind the retaining bolts Is the socket doweled? If I undo the four bolts holding on the socket can I change the cam timing? Does anyone have a photo of the cam shaft encoder off a M42? The cam timing is adjustable +/- 6 degrees IIRC. loosen the bolts and the sprocket moves about. What do you want a photo of the Cam Position Sensor for? It is the sensor on the front of the upper timing cover infront of the exhaust cam. Looks alot like the Crank Position Sensor. Edited March 28, 2010 by e30guydownunder Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted March 28, 2010 (edited) The cam timing is adjustable +/- 6 degrees IIRC. loosen the bolts and the sprocket moves about. What do you want a photo of the Cam Position Sensor for? It is the sensor on the front of the upper timing cover infront of the exhaust cam. Looks alot like the Crank Position Sensor. I'm looking for a picture of the plate that bolts to the cam that the sensor picks up, like the plate that is on the inlet cam in the photo Edited March 28, 2010 by rot62 Quote Share this post Link to post Share on other sites
e30guydownunder 2 Report post Posted March 28, 2010 I'm looking for a picture of the plate that bolts to the cam that the sensor picks up, like the plate that is on the inlet cam in the photo Sorry I can't see the pictures currently. On the M42's I have stripped there has never being a plate on the intake cam (was this a M44?) anyway there is a pin in the front of the exhaust sprocket (well both sprockets, as they are the same) and this is the trigger on the M42. I see that an M44 is different: http://www.realoem.com/bmw/showparts.do?mo...hg=11&fg=25 Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted March 29, 2010 Sorry I can't see the pictures currently. On the M42's I have stripped there has never being a plate on the intake cam (was this a M44?) anyway there is a pin in the front of the exhaust sprocket (well both sprockets, as they are the same) and this is the trigger on the M42. I see that an M44 is different: http://www.realoem.com/bmw/showparts.do?mo...hg=11&fg=25 Thanks- it would seem that only M44 has the plate and not on a m42. I just thought there may have been a similar thing on the m42 Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted March 30, 2010 (edited) Good news tonight- I got the engine running using the Jaycar ignition kit and a wasted spark module from NZEFI. Due to the programmable ignition controller being only a single channel system, I had to modify the factory M44 camshaft encoder just to give me a signal for cylinders 2&3. Then the signal from the factory cam sensor was put into the wasted spark module. This module toggles the output from the controller to fire 1&4 and then switches to fire 2&3. I used a Subaru reluctor and installed bolts in the front pulley to give the ignition controller a reference for cylinder 1 & 2 TDC. Edited March 30, 2010 by rot62 Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted March 30, 2010 Heres a vid of the engine running Quote Share this post Link to post Share on other sites
JFry 1 Report post Posted March 30, 2010 That is awesome dude! Well done Quote Share this post Link to post Share on other sites
tire 10 Report post Posted March 30, 2010 Loving that video...wish I knew how to do all that. Congrats dude. Quote Share this post Link to post Share on other sites
mark247 43 Report post Posted March 30, 2010 Makes me wish I had the skills to undertake such a project. That is a great little setup. Quote Share this post Link to post Share on other sites
e30guydownunder 2 Report post Posted March 30, 2010 Great work mate. Love how the ignition setup worked out for you. Those coils look like they are off a 4AGZE I recon this will sound beaut once its up and running in the car. Keep steaming away with the progress. Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted March 30, 2010 Great work mate. Love how the ignition setup worked out for you. Those coils look like they are off a 4AGZE I recon this will sound beaut once its up and running in the car. Keep steaming away with the progress. sure are- 4agze Going to add a map sensor next to help control the timing. The kit can have two ignition maps - say for if you are using different fuels . Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted March 30, 2010 pretty awesome fella! .. weldone! I had some one in the states the other day ask me why Im bothering with trying to get EWS going and why I didnt just pay someone to align it for me. I just told them, well yeah you can do that and not learn a thing. I like you attitude to this whole project, work out how to do it yourself and stick to your guns. again, hat off to you sir. much respect from this end of the woods. Quote Share this post Link to post Share on other sites
sp8s 1 Report post Posted March 30, 2010 What else can I say but Well done Quote Share this post Link to post Share on other sites
