_ethrty-Andy_ 2144 Report post Posted February 14, 2010 found them on trademe (listing just expired so no link as yet), anyone have any comments to make about them? they seem cheaper than alternatives, do you really get what you pay for for this sort of thing? my car is exclusively street spec/DD at the moment, with maybe a few track days in the future, so i dont need to drop 10k on suspension. My rear shocks are blown and the fronts arent far off it either so no point spending on an inferior product. Also B'Days coming up Quote Share this post Link to post Share on other sites
e30ftw 428 Report post Posted February 14, 2010 From what I remember they are a Taiwan based company. 'Nuf said. Quote Share this post Link to post Share on other sites
Mattzy 0 Report post Posted February 14, 2010 BC's are also Taiwanese, and I have used them in several of my cars with no problems. Hell, I even used 2nd hand ones in my S14 and they took a beating. I haven’t heard of anyone in NZ using XYZ, but their website seems to suggest they follow ISO 9001 which means they at least have some form of quality control. From what I remember GC and IE are around the 3k mark. (someone chime in here) So I guess your budget will really determine what works for you. Don’t be put off by the fanboys. Make sure the kit is complete with C spanners and adjusters and you'll be fine. Contrary to what people believe you can actually build a car that’s fun and cheap! PS - Remember to budget installation (If they need to be welded - best to speak with certifier prior) and the appropriate certification. (hides and waits for rage) Quote Share this post Link to post Share on other sites
e30ftw 428 Report post Posted February 14, 2010 Fair call, I was thinking d2's were also Taiwanese. But BC have way better rep, unlike d2's. Ground controls do infact cost close to the $3000 after shipping, then GST once they get in the country, then welding install. All adds up very fast.. Quote Share this post Link to post Share on other sites
Mattzy 0 Report post Posted February 14, 2010 e30ftw said: Fair call, I was thinking d2's were also Taiwanese. But BC have way better rep, unlike d2's. Ground controls do infact cost close to the $3000 after shipping, then GST once they get in the country, then welding install. All adds up very fast.. For sure dude. I'd personally still stray away from D2's if buying 2nd hand, going by friends experiences the adjusters break and the original design was weak. Had a friend's S14 snap the main tube at puke (back in '06) Quote Share this post Link to post Share on other sites
zenetti 0 Report post Posted February 14, 2010 You also have to remember that they are deisgned for a purpose. D2's were (are) not designed for track use. They are designed as a street application, but primarily got a bad rep from people using them for drifting on the track. For street use most of the Taiwanese kits will be fine. As Matt said just look for the ones that have some form of quality control such as ISO9001 or even better ISO9002. At the end of the day it comes down to your budget, and what you want to use your vehicle for. Quote Share this post Link to post Share on other sites
Mattzy 0 Report post Posted February 14, 2010 zenetti said: You also have to remember that they are deisgned for a purpose. D2's were (are) not designed for track use. They are designed as a street application, but primarily got a bad rep from people using them for drifting on the track. Well said. Quote Share this post Link to post Share on other sites
JiB 2 Report post Posted February 14, 2010 I was thinking about this the other day. The main issue (I think) with cheap coilover kits is the damping is a bit shithaus. Can you get the specs of the XYZ shock insert? Maybe replace it with koni, et al damper matched to your spring rate? And yes my GC's were circa $3k+ all up. Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted February 14, 2010 I do have to ask this for a road car... Why do you want coilovers? Do you want to play with your ride height? Or are you just looking to upgrade your suspension? If it's just upgraded suspension look for some decent adjustable damper shocks, and some decent springs. Then you don't need a cert or a wheel alignment every time you adjust your suspension. Quote Share this post Link to post Share on other sites
MLM 57 Report post Posted February 14, 2010 zenetti said: For street use most of the Taiwanese kits will be fine. As Matt said just look for the ones that have some form of quality control such as ISO9001 or even better ISO9002. That ISO standard, does not guarantee a quality component it just ensures quality control processes are adhered to in the manufacture. Ie If is crap part due to design or materials it will be consistently crap. Are there other automotive standards to look for? I have seen TUV, DOT approved etc Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted February 14, 2010 TUV is a european standard = i know with wheels the TUV spec wheels are much much heavier than the jap/asia spec wheels. Quote Share this post Link to post Share on other sites
Top Secret 2 Report post Posted February 15, 2010 I actually went and talked to Evan at Speedfactor about these very coil overs a while ago. He is a very knowledgable guy, and I asked him specifically about the quality and after sale support for the XYZ coil overs. He said he can tailor the spring rates to suit you (from memory), and that they use XYZ coil overs in their SS2000 class Civic with good results. When I pressed him about the quality, he said he was impressed by it. $1300 from Speedfactor. Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted February 15, 2010 Start with some KONI damper adjustable shocks, they might seem expensive just for the shocks but at least you know you are getting something really high quality with damping adjustment you can rely on. Street car or track car, if the damping is a bit willy nilly it wont ever feel right. and if you need coil over style adjustment buy the rest of the GC kit later on as you can afford it I had Koni's & eibachs in my old E30 and it drove amazingly well $1300 for some complete coil overs might seem like a good deal but the koni's really are an investment as they can be used as part of the GC kit at a later date. can you tell I'm a fan of Koni ? My mate has some D2's in his subaru and I have to admit they actually arn't too bad at all but his were quite new and I still don't trust their longevity Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted February 15, 2010 Yep, at the current exchange rate the GC kit cost me $2500 odd. Then freight, then GST and installation Quote Share this post Link to post Share on other sites
Mattzy 0 Report post Posted February 15, 2010 Self plug time! Drop me a line if any of this takes your fancy http://www.trademe.co.nz/Browse/Listing.aspx?id=272151574 Cheers, Matt Quote Share this post Link to post Share on other sites
zenetti 0 Report post Posted February 15, 2010 ^^^ BUY THESE!!! Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2144 Report post Posted February 15, 2010 Im not really looking for coilovers as such. im looking for an upgrade to what i have as i need to replace all four shocks. They just caught my eye because they were cheapish. Certification doesnt really bother me as the car is going to need to be cert-ed for the engine swap anyway so they can do it all at once. hmmmm H&R.... Quote Share this post Link to post Share on other sites
Jeddy 0 Report post Posted February 15, 2010 I think it would be best to go with the H&R's Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted February 15, 2010 Jeddy said: I think it would be best to go with the H&R's +1 you know what you are getting Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted February 15, 2010 (edited) Jimmy said: Start with some KONI damper adjustable shocks, they might seem expensive just for the shocks but at least you know you are getting something really high quality with damping adjustment you can rely on. I had Koni's & eibachs in my old E30 and it drove amazingly well I have this set up and totally agree. If the race series E30's use Koni Adjustables they can't be bad shocks, I think mine are fantastic, the best money I have spent on the car. IMO buy Mattzy's H+R set up on trade me, I dare anyone to tell me it's not a bargain. Edited February 15, 2010 by Forrest Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted February 15, 2010 Buy Mattzy's set... Proven setup > Unknown XYZ coils Plus is cheaper Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2144 Report post Posted February 15, 2010 as long as its still there on thursday! Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted February 15, 2010 Buy the H&Rs. Jimmy said: $1300 for some complete coil overs might seem like a good deal but the koni's really are an investment as they can be used as part of the GC kit at a later date. This isn't quite right - the Koni's used in the GC kit are special shorter ones (I expect they're for something else, but revalved to suit an E30's weight etc). As they're shorter, you can shorten the struts and still have the springs captive. Quote Share this post Link to post Share on other sites
morpheusmaster 0 Report post Posted November 4, 2011 Hey men. I have one question. Did somebody actually ordered from xyz-racing.com ?? Are they trustfull? Thanks in advance Quote Share this post Link to post Share on other sites
thorburn 122 Report post Posted November 4, 2011 Have a talk to speed factor in Tauranga http://speedfactor.co.nz/ They have plenty of people using them in their race cars. Not sure what trustful is but speed factor do stand behind them Quote Share this post Link to post Share on other sites
