dubman 39 Report post Posted February 21, 2010 (edited) I screwed up one of the bolts when re attaching my wheels, now the bolt and the hole are stuffed!!!. need a hub cheers 0211565540, text me and i'll call back Edited February 21, 2010 by dubman Quote Share this post Link to post Share on other sites
3series 0 Report post Posted February 21, 2010 You dont need a complete new strut, just replace the hub/bearing. Quote Share this post Link to post Share on other sites
dubman 39 Report post Posted February 21, 2010 so just the hub centre bit? cheers Quote Share this post Link to post Share on other sites
Driftit 2248 Report post Posted February 21, 2010 BNT have them. They usually fall apart when you pull them off the strut. So 2nd hand is unlikely. Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted February 21, 2010 What size strut do you have? If its 45mm then I can supply an entire strut for less than a hub, saves you the hassles of fitting the hub aswel. Quote Share this post Link to post Share on other sites
APT 205 Report post Posted February 21, 2010 bro just replace the strut i reckon its a whole lot easier and just bolts on straight BTW this happend to me the otherday Quote Share this post Link to post Share on other sites
HELLBM 1697 Report post Posted February 21, 2010 We can do 51mm. have either ABS or non ABS. Call/text me. regards Ray 0212435526 Quote Share this post Link to post Share on other sites
Andre3000 55 Report post Posted February 21, 2010 I've got a few 51mm hubs lying around too if you want em Quote Share this post Link to post Share on other sites
dubman 39 Report post Posted February 21, 2010 visiting ray 2moro. cheers for all the input guys. 36mm socket + hub is more expensive than a strut most likely. Quote Share this post Link to post Share on other sites
