cliffdunedin 8 Report post Posted February 24, 2010 Hi guys i'm looking at some 17's on TM but have no idea on the whole offset thing Can anyone please give me a quick explanation on the whole 5 x 120 etc Cheers Quote Share this post Link to post Share on other sites
greenday-rulz21 6 Report post Posted February 24, 2010 5x120 is the stud pattern. 5 is obviously the number of studs or bolt holes and the 120 is the diameter of the studs (mm) as in the picture below. For example e30 is 4x100, 4 lug holes and a diameter of 100mm The offset is the distance from the mounting face to the centerline of the wheel (measured in mm). Zero offset means the mounting face is in line with the centerline of the wheel. Positive means the mounting face is towards the outside of the wheel. Negitive is the opposite, mounting face towards the inside of the wheel. Higher positive offsets are generally found on front wheel drive cars. Negitive offsets are generally associated with large amounts of dish (with a large width). BMW's run positive offsets. E28, E30, E34, E38, E39 etc (The majority of the BMW range) run offsets in the range of 15-25 running normal factory widths. The E36 chassis (E36/Z3), E46 (non M3), E53, E70, E8X, E9X all run higher offsets in the range of 35-45 running factory widths. The E21 and the E30 are the only E code bimmers that run 4 stud. The rest of the range runs 5x120. As the wheels get wider the offset you will need for the car will change as if you increase the width but keep the same offset the wheel will get wider evenly on both sides and may either hit the strut or the guard. Generally as you get wider you would want to lower the offset as you have more room to work under the guards than towards the strut. Hope that helps. 2 Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted February 24, 2010 Nice explanation Nick. Was reading through to see if there was anything to add, but for a n00b guide it pretty much covers it. Stickied. Quote Share this post Link to post Share on other sites
greenday-rulz21 6 Report post Posted February 24, 2010 Cheers Graham. Yea, pretty simple but it covers the main fitment ideas with some BMW reference. And it was late at night so reading it now it seems ok! Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted February 25, 2010 Thanks mate, I had a general idea but was not 100% cheers for your help! Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted August 26, 2011 Hey guys here's another handy site for PCD's and offsets; http://www.carlsalter.com/wheel_fitments.html Quote Share this post Link to post Share on other sites
02e46m-sport 1 Report post Posted October 23, 2012 Hey guys here's another handy site for PCD's and offsets; http://www.carlsalter.com/wheel_fitments.html whats the max offset that would fit in the rear of an e46.. looking at 19s 9.5s at the rear wanting max offset with lil work done probs just roll guards..would 20p fit? Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted October 24, 2012 -38 for normal fitment tires. going illegal you'll get -20 to fit. Quote Share this post Link to post Share on other sites
dreadful1 7 Report post Posted October 24, 2012 (edited) I've had 24p on the rears for 19x9.5 and tire size was 235/35/19 which was just the legal limit for stretch and it rubbed even with pumped guards+slight flare. At the moment I have 19x9.5 38p and 265/30/19 and its fine with no rubbing but its on the borderline of clearance. I would say 30p would be a safe option if you want the low offset look + legal tires and a little stretch and no rubbing! Edited October 24, 2012 by Yongxi Quote Share this post Link to post Share on other sites
hunter 413 Report post Posted April 21, 2013 Hey guys, fairly new to the wheel and offset topics, would a 18 x 9.5 et35 rear fit my e46 sedan without rubbing? Cheers Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted April 21, 2013 I'm running 19x9.5 35 offset with 245,35s on my touring and guard wise it's pretty good for clearance with just a roll. Running jamex superlows Quote Share this post Link to post Share on other sites
hunter 413 Report post Posted April 21, 2013 I'm running 19x9.5 35 offset with 245,35s on my touring and guard wise it's pretty good for clearance with just a roll. Running jamex superlowsCool, thanks mate, so no to little rubbing im guessing?I don't want any rubbing but want a nice concave wheel. thinking about APEX Arc 8s Quote Share this post Link to post Share on other sites
