thorburn 121 Report post Posted April 25, 2010 (edited) Got this car a little while back. It was cheap and as a result it was (and still is) a bit rough. What i will be trying to do is restore it and make it go around corners a little nicer. So far i have: -swaped the standard open 2.92 diff to a 3.15 lsd -changed the rear shocks to bilstein sports -added remus rear muffler -re-sprayed the parcel tray from some sort of pink color to black Here it is now: Things i need to fix: -rubbers around windows -broken fuel gauge. Always shows empty. I think it is the fuel level senders that are the problem -holes in boot from spoiler + flaking paint on boot -respray bumper trim -replace front emblem -tensioner bearing -ac removed -fan clutch -radiator hoses -front brakes -exhaust rattle -clutch Edited September 10, 2011 by bbs Quote Share this post Link to post Share on other sites
dirtydoogle 383 Report post Posted April 25, 2010 How much did you pay for that? I'm loving the red interior Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted April 25, 2010 How much did you pay for that? I'm loving the red interior yes nice interior . sorry to hijack the thread can get you a red and black interior in nappa leather from a individual spec'd e36 coupe . black cards with stitched in red leather inserts . black leather sport seats with red leather inserts down the middle . $800 the set Quote Share this post Link to post Share on other sites
dirtydoogle 383 Report post Posted April 25, 2010 I'd do that, excpet mine has been re-upholstered and sold. Sick of it falling apart. Quote Share this post Link to post Share on other sites
thorburn 121 Report post Posted April 25, 2010 think it was 6 cheapest factory manual e36 328 i've seen I didn't like the interior at all to start with but it has grown on me Forgot to add the best bits about the car. No traction control, no cruise control, no head unit and no obc Quote Share this post Link to post Share on other sites
dirtydoogle 383 Report post Posted April 25, 2010 think it was 6 cheapest factory manual e36 328 i've seen I didn't like the interior at all to start with but it has grown on me Forgot to add the best bits about the car. No traction control, no cruise control, no head unit and no obc That's a great deal! I wish I could spare the money for something like that Quote Share this post Link to post Share on other sites
thorburn 121 Report post Posted May 1, 2010 (edited) Sorted the fuel level sender. Seems to be a ver common problem for 95-on e36's and is 9 times out of 10 on the fuel pump side. Very easy to fix. Pop out rear seat, unscrew the cover on the drivers side(4 phillips head screws), unplug the level sender and fuel pump wiring, unscrew the cover from the fuel pump. I used a hammer and large flathead to beat it around. Carefully remove the fuel pump where if your lucky you'll see this: Was just a loose wire. Use a wire stripper to expose more wire if necessary and screw back into it's spot. Install is opposite to removal. The smell of petrol went after a short drive If your an idiot this could be dangerous quite happy to not have to carry the safety bottle around. then swaped old for new tensioner bearing, belts and bonnet emblem Edited March 26, 2011 by bbs Quote Share this post Link to post Share on other sites
thorburn 121 Report post Posted May 16, 2010 (edited) Started adding m3 bits to my car Lemforder offset control arm bushes and Meyle heavy duty outer ball joints. I had these installed by Coombes. For the price i paid it'd probably be cheaper to buy a press and do it yourself. m3 Bilstein struts, H&R m3 sport springs, Lemforder m3 evo strut tops, m3 strut top reinforcement plates + other bits Before: After: (after this photo my craving for camber kicked in, so I switched the top hats) Still need to sort out a front sway bar that will be suitable for attaching to the strut. At the momment i am thinking i will try use a 23.5mm bar out of a 318. I have no idea if this will work so any advice would be great Edited March 26, 2011 by bbs Quote Share this post Link to post Share on other sites
dirtydoogle 383 Report post Posted May 16, 2010 Looks like it's coming along well! If only I could afford such a project. Isn't there a decent size sway bar you could use instead of a 318i one? Quote Share this post Link to post Share on other sites
thorburn 121 Report post Posted May 16, 2010 (edited) the 318 bars are thicker then m3 bars. See here for more details: http://www.bimmersport.co.nz/forums/index....showtopic=29776 Does anyone have some 23.5mm sway bars that i can borrow for a trial fit? Edit: Ditched this idea and now have a 23mm swaybar that fits. Just for future reference Edited May 20, 2010 by bbs Quote Share this post Link to post Share on other sites
thorburn 121 Report post Posted May 18, 2010 (edited) Just took the car in for a wheel alignment and i have a problem. Caster L=5.88' R=5.95 Camber L=-1.87' R=-1.25' What would create such a difference in camber? My first guess would be my control arm is bent on the right side. Any help would be much appreciated Edit: control arms are the same length and the cause was a washer that was stuck with lock tight between the shock and spindle Edited May 20, 2010 by bbs Quote Share this post Link to post Share on other sites
thorburn 121 Report post Posted May 24, 2010 (edited) Continued to move parts from the corner of my room to my car. This weekend was fan delete and coolant flush. Link that helped: http://www.understeer.com/fanclutchmod.shtml Fan delete used 80 degree thermostat (11 53 1 466 174) and 80/88 degree fan switch (61 31 8 376 440) I will be getting an electric fan to go in place of the original fan at some stage. Does anyone have any links to one of a suitable size? And i need to think of how i want to wire it in once i do get it No change felt but it is a little bit more weight out of the car and it's hopefully worthwhile preventative maintenance (Later I put the fan back in the car, i will still be getting an electric fan) Next step is getting my wheels fixed and sorting out the clutch Edited March 26, 2011 by bbs Quote Share this post Link to post Share on other sites
thorburn 121 Report post Posted June 16, 2010 (edited) got some new toys plus e34 m5 clutch, pressure plate, throwout bearing and flywheel bolts Still need to buy pilot bearing,throwout arm pivot and flywheel seal and need to borrow, rent or buy a clutch allignment tool(edit: just use a rod with tape wrapped around it) I also want to replace the shifter bushes while i'm in there. Not really sure what is necessary to replace. If anyone could inlighten me that would be much appreciated anything else i should replace while i'm in there? guibo is in good condition and mounts will be replaced with e21 items (i think that's what they are from) (edit: guibo was replaced anyways) Edited March 26, 2011 by bbs Quote Share this post Link to post Share on other sites
tire 10 Report post Posted June 16, 2010 (edited) Cool thread man, good to see you've got praying mantis approval. You could borrow my clutch alignment tool if you were in Auckland. Edited June 16, 2010 by tastic Quote Share this post Link to post Share on other sites
Creaver 55 Report post Posted June 16, 2010 Looking awesome man. Will be watching this thread! Quote Share this post Link to post Share on other sites
[email protected] 0 Report post Posted June 16, 2010 Fantastic mate. Always pleasing to see someone taking the time to make an already decent car even better. What are you doing for brakes? Are you going as far as fitting the M3 rear sub frame point reinforcement plates and front sub frame underside 'X' Cross bar? Quote Share this post Link to post Share on other sites
Guest Simon* Report post Posted June 16, 2010 Nice upgrades. Definitely approve of Mantis approval. Did you order the UUC gear direct from them? Shortshifter.com isn't it? Quote Share this post Link to post Share on other sites
thorburn 121 Report post Posted June 16, 2010 Fantastic mate. Always pleasing to see someone taking the time to make an already decent car even better. What are you doing for brakes? Are you going as far as fitting the M3 rear sub frame point reinforcement plates and front sub frame underside 'X' Cross bar? For brakes i'll be getting some slotted brembo's for the front and genuine pads. I've also got come braided lines from alert engineering. Might also rebuild the calipers I've also got those brembo calipers that I might fix up and get rotors built for at a later date I've already purchased the rear subframe reinforcement plates and an xbrace after seeing the subframe reinforcement plates in person i wish i'd just made them up Quote Share this post Link to post Share on other sites
[email protected] 0 Report post Posted June 16, 2010 I've already purchased the rear subframe reinforcement plates and an xbrace after seeing the subframe reinforcement plates in person i wish i'd just made them up What did you get stung for those? Quote Share this post Link to post Share on other sites
thorburn 121 Report post Posted June 16, 2010 Nice upgrades. Definitely approve of Mantis approval. Did you order the UUC gear direct from them? Shortshifter.com isn't it? Yes i did. Rob was great to deal with. I got in contact with him first in regard to their blemished parts deal. He made everything as easy and cheap as from there. You might notice some slight blemishes on the paint of the flywheel. theres a slight scratch on the paint on the other side as well. Nothing that effects the function of the product Quote Share this post Link to post Share on other sites
Gaz 1065 Report post Posted July 11, 2010 That is a frighting pink letter, good to hear that it all worked out in the end. What are the specs on the style 19s? Quote Share this post Link to post Share on other sites
thorburn 121 Report post Posted July 11, 2010 My first reaction was that someone was having me on. 17x8 et20 they are just touching my un-rolled gaurds in the back. Haven't yet tried them on the front. Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted July 11, 2010 well that would rip your undies pulling it apart for nothing. Quote Share this post Link to post Share on other sites
thorburn 121 Report post Posted July 12, 2010 I actually quite enjoyed pulling it apart. Some bits were a waste of time taking apart though. I've been planning on freshening up a few things for awhile so i'd might as well get them done while I'm in there. List so far: belt tensioner shifter bushes clutch stuff flywheel seal pilot bearing reseal diff replace brakelines and fluid m50 intake replace steering rack line that's leaking.maybe find z3 rack possibly get injectors cleaned headers Any recomendations on what brakefluid to use? the car is used mostly for exploring the mint roads we have around the country Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted July 12, 2010 Motul 5.1 Quote Share this post Link to post Share on other sites
