e30ftw 435 Report post Posted May 9, 2010 Looking for a 3.46 medium case or lower ratio e30 diff. Output flanges / rear cover or mount etc don't bother me, mainly after the gears and housing to swap my LSD center over to it. The 3.64 is driving me nuts, 3300rpm @ 100kmh.. Also a 325i full driveshaft if anyone has one liying around. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 9, 2010 (edited) Is that ratio really the ratio you want ? Calculating a diff ratio you have to take into consideration: What is the car being used for... road or track Transmission output ratio ie: 1:1 or overdrive = normally .8 What RPM is the engine power band Achieveable top speed (calculated) Power to weight ratio of the vehicle Engine torque Wheel & tyre sizes (rolling circumference) These are some calcs I did using 225/45/17 (634.3mm) for my examples. The RPM will be different dependant on tyres & wheel size. I can change these calcs if I knew your tyre size. These examples I did with my tyre size. 3.64:1 @ 100Kph = 3,050 RPM 3.46:1 @ 100Kph = 2,900 RPM 3.15:1 @ 100Kph = 2,650 RPM 2.97:1 @ 100Kph = 2,500 RPM To have 3,300 RPM @100KPH you must be running smaller tyres/wheels or your rev counter or speedo is out My car with 1:1 trans output, 3.15:1 diff and 225/45/17 tyres is reading 2,700RPM @ 100kph. In hinesight I could of gone to a 2.97:1 with the torque produced by the M52 B28 and the power to weight ratio. I don't really need to use 1st gear. Edited May 9, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted May 9, 2010 have a few options . 021433600 092991234 thanks brent Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted May 9, 2010 To have 3,300 RPM @100KPH you must be running smaller tyres/wheels... ...225/45/17 tyres I hope he's running smaller diameter than that on an E30! John - I agree with Glenn - you need to consider what you want and a 3.46 doesn't sound like it. It will only drop you to 3100ish rpm. What's the goal? Low rpm/fuel economy or acceleration/performance? Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted May 10, 2010 205/40 16's Just after something lower.. Have PM'd you Brent. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 10, 2010 With 205/40/16 3.64:1 @ 100Kph = 3,380 RPM 3.46:1 @ 100Kph = 3,200RPM 3.15:1 @ 100Kph = 2,930 RPM 2.97:1 @ 100Kph = 2,800 RPM Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted May 10, 2010 What calc are you using? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 10, 2010 Ooops I was doing my calcs with gearbox output at 1:1 your 240 or 260 should be .81:1 3.64:1 @ 100Kph = 2,742RPM 3.46:1 @ 100Kph = 2,600RPM 3.15:1 @ 100Kph = 2,375 RPM 2.97:1 @ 100Kph = 2,240 RPM Check your 5th gear output ratio.... are you sure your diff is a 3.64:1 ? 3,300 Rpm @ 100kph seems too high, unless the rev counter is out. I don't know what your gearbox output ratio is if it is 1:1 the previous rev ranges are correct Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted May 10, 2010 Yes its a 3.64 diff and it's an e36 getrag 220 gearbox so 1:1 5th gear. Just curious on all gear speeds but I'll have a looksy round. The 3.64 with the getrag 240 .81:1 was pretty good, maybe a lil too long but something similar (slightly higher) in comparison with the 1:1 box im using now and whatever diff I can get. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted May 10, 2010 hes using a 220 with a 5th gear of 1:1 iirc? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 10, 2010 If its 1:1 the first set of calcs are correct then Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted May 10, 2010 (edited) 3.64*0.81 = 2.95 (assuming a 1:1), so you'd want a 2.97 (or a 3.15 if shorter). Rev calculator (doesn't work very well in firefox): http://members.dodo.com.au/~wawawa/revs.htm Edited May 10, 2010 by CamB Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted May 10, 2010 Sweet, Anywhere 2.97 to 3.25 will be sweet. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 10, 2010 This is a better calculator to use. Load tyre size first, calculate, then put g/box output ratio in the 6th gear box and do the maths. It's usefull for 6 & 5 speed gearboxes http://www.unixnerd.demon.co.uk/revs.html Quote Share this post Link to post Share on other sites
mitchE30 0 Report post Posted May 10, 2010 thanks glenn.nice website. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 10, 2010 (edited) Sweet, Anywhere 2.97 to 3.25 will be sweet. Getting the right ratio in a medium case that will fit your E30 is probably going to be a problem though. I ended up getting a diff from Brent. It was out of an E28 to get the crownwheel & pinion. Then had the LSD, crownwheel & pinion & a full set of new bearings installed and set up by Diff Specs using a solid preload spacer for the pinion instead of the collapsible sleeve. Not cheap to do unfortunately. Edited May 10, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted May 10, 2010 Getting the right ratio in a medium case that will fit your E30 is probably going to be a problem though. I ended up getting a diff from Brent. It was out of an E28 to get the crownwheel & pinion. Then had the LSD, crownwheel & pinion & a full set of new bearings installed and set up by Diff Specs using a solid preload spacer for the pinion instead of the collapsible sleeve. Not cheap to do unfortunately. was from e34 530i V8 auto . 3.15 ratio . also a comon ratio found in the e36 325i manual's i have a530i v8 diff that will be coming out soon . have a 2.93 medium case from a e28 525e auto on the shelf Quote Share this post Link to post Share on other sites
HELLBM 1697 Report post Posted May 10, 2010 Can do 3.93, 3.15 both in medium case. LSD`s 3.64 and 3.73. Other options avaliable. Quote Share this post Link to post Share on other sites
