Grant 4 Report post Posted March 20, 2005 Hi All I have smashed one of my fog/driving lights (I had a bit of a 1,500km roadtrip over the weekend) and it is good timing as my WOF expires today. Am I still able to get a WOF if I remove the foglights completely for the time being (until I get a new one). Please can I just have an actual factual answer (I want to know for sure), not one that is based purely on speculation. Cheers Quote Share this post Link to post Share on other sites
MattA 165 Report post Posted March 20, 2005 Correct Grant if you remove both lights, as they are auxillary lights. I have removed mine for the same reason (both broken) and never been asked about it. I now have blanks in the holes but didn't to begin with. cheers Matt Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted March 20, 2005 Funny isn't it, I read into that aswell that if you have auxillary lights then they must work...aswell is be in the correct place. I saw some lights on Trademe last week that you could've snaffled up Quote Share this post Link to post Share on other sites
CaM 0 Report post Posted March 20, 2005 does anyone on here put stick on light skins or protectors on their fog lights??? they seem to be the most commonly f**ked over thing on bmws, I think sparkle has had more smashed foglights than he has stonechips on the front of his car.... he's done like 4 now i think Quote Share this post Link to post Share on other sites
Grant 4 Report post Posted March 20, 2005 ///Carl said: I saw some lights on Trademe last week that you could've snaffled up GRRRRR. I saw them too, and thought I should buy them, as this isn't the first time I have smashed one.Ain't hindsight a wonderful thing. I have rung 4 different BMW wreckers places this morning, each have said that that are hot property, and they don't have any in stock. One new one is $245 + GST from BMW. Also, thanks Matt for your answer, looks like I'll have to do that in the interim. Cheers Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted March 20, 2005 The ph number of the guy with the fogs is 094210897 or 0211625615. Ring him and see if he still has them. They were F/L fogs. Quote Share this post Link to post Share on other sites
m325i 722 Report post Posted March 20, 2005 Pretty sure Hella do a copy that fits Quote Share this post Link to post Share on other sites
CaM 0 Report post Posted March 20, 2005 hella make the OEM one.... still pricey unless you got hookups, and harder to get then pre facelift Quote Share this post Link to post Share on other sites
aliluya 0 Report post Posted March 20, 2005 (edited) Grant said: Hi All I have smashed one of my fog/driving lights (I had a bit of a 1,500km roadtrip over the weekend) and it is good timing as my WOF expires today. Am I still able to get a WOF if I remove the foglights completely for the time being (until I get a new one). Please can I just have an actual factual answer (I want to know for sure), not one that is based purely on speculation. Cheers Yes you can remove the lights completely and pass the warrant.Because when i had some fogs installed and hadn't wired it up and took it down to the warrant place they gave me two options.. one to wire it up and second to take them out... And covering them with something doesn't solve the problem either.. lol.. i asked about that at the time... Edited March 20, 2005 by aliluya Quote Share this post Link to post Share on other sites
Grant 4 Report post Posted March 20, 2005 bravomikewhiskey said: The ph number of the guy with the fogs is 094210897 or 0211625615. Ring him and see if he still has them. They were F/L fogs. GiddayNo, Roy doesn't have any at the moment. Cheers Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted March 20, 2005 This is abit of a grey area, i have had 1st hand dealing with the testing station over this in my old mans 4x4. I have been told you can have the fog lights there for decoration only(not working) or as others have said you need them removed if not working, and when they have been disconnected i have had to connect them or remove them. so go figure??? Try ring the LTSA 0800 number and ask them. They are the only people i think know the 100% truth. Not some testing station tester inturptation(sp) on the law. Grant, have you completely smashed or just cracked the fog lights? cause i think you can get away with cracked ones Quote Share this post Link to post Share on other sites
Grant 4 Report post Posted March 20, 2005 bumpstop325 said: This is abit of a grey area, i have had 1st hand dealing with the testing station over this in my old mans 4x4. I have been told you can have the fog lights there for decoration only(not working) or as others have said you need them removed if not working, and when they have been disconnected i have had to connect them or remove them. so go figure??? Try ring the LTSA 0800 number and ask them. They are the only people i think know the 100% truth. Not some testing station tester inturptation(sp) on the law. Grant, have you completely smashed or just cracked the fog lights? cause i think you can get away with cracked ones Cool, I'll call them.Yup, I have completely smashed it. Must have been a big stone. Cheers Quote Share this post Link to post Share on other sites
aliluya 0 Report post Posted March 20, 2005 bumpstop325 said: This is abit of a grey area, i have had 1st hand dealing with the testing station over this in my old mans 4x4. I have been told you can have the fog lights there for decoration only(not working) or as others have said you need them removed if not working, and when they have been disconnected i have had to connect them or remove them. so go figure??? Try ring the LTSA 0800 number and ask them. They are the only people i think know the 100% truth. Not some testing station tester inturptation(sp) on the law. Grant, have you completely smashed or just cracked the fog lights? cause i think you can get away with cracked ones No .. in the LTSA rule book it said if it's there it HAS to be working ... otherwise you will fail your warrant ....Otherwise you'd have to remove them ... Quote Share this post Link to post Share on other sites
Juzzie Wuzzie 0 Report post Posted March 20, 2005 For three years, my 2002tii got WOFs no problem, then one day, out of the blue - FAILED "you need park lights sunny". "But sir, six WOFs previously have said otherwise". I think many WOF people can only handle the stock standard stuff, and get uneasy / unsure / make it up regarding classics, etc. IMHO Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted March 21, 2005 I try to stick to the LTSA licensing places unless getting something done close to WOF time. Similar prob, had an isuzu for several years then one day they failed me for not having a high stop light...bistirds Quote Share this post Link to post Share on other sites
