E30 325i Rag-Top 3041 Report post Posted November 23, 2010 Tools Explained DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it. WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, "Oh, sh*t!" SKILL SAW: A portable cutting tool used to make studs too short. PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters. BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs. HACKSAW: One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes. VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand. OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.. TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity. HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper. BAND SAW: A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge. TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect. PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but, can also be used, as the name implies, to strip out Phillips screw heads. STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms. PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part. HOSE CUTTER: A tool used to make hoses too short. HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit. UTILITY KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while you are wearing them. Son of a b*tch TOOL: Any handy tool that you grab and throw across the garage while yelling "Son of a bitch" at the top of your lungs. It is also, most often, the next tool that you will need. Quote Share this post Link to post Share on other sites
oscar90 0 Report post Posted November 23, 2010 Love it haha Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted November 24, 2010 (edited) Utility Knife, I've destroyed so many things without even knowing it. Edited November 24, 2010 by Blackie Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted November 24, 2010 ^ Lol yep, fabric samples are the worst . Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted November 24, 2010 People opening boxes of coke with knives is a good way to destroy a few grand worth of computer hardware.... Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted November 24, 2010 Tools Explained HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper. every single time. and my cars arent even that low haha Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted November 24, 2010 GOLD Jon. So bloody true! Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted November 24, 2010 brilliant! Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted November 24, 2010 Son of a bitch! Quote Share this post Link to post Share on other sites
Guest Simon* Report post Posted November 24, 2010 a few more funnies recently read .... In a pub quiz the other day I lost by one point. The question was where do women mostly have curly hair? Apparently, it's Africa One of the other questions was to name two things commonly found in cells. It appears that gang members and bum sex is not the correct answer I've heard that Apple have scrapped their plans for the new children's iPod after realizing that iTouch Kids is not a good product name. My wife told me I was no longer romantic so I booked a table for the two of us on Valentine's Night. Problem was she sucks at snooker and pool There's a new Afghani clothing shop opened in Hastings but I've been banned from it after asking to look at some bomber jackets A biker goes to the doctor with hearing problems. "Can you describe the symptoms to me?" asked the doctor. "Yes. Homer is a fat yellow lazy bastard and Marge is a skinny bird with big blue hair." Just put a deposit down on a brand new Porsche & mentioned it on Facebook. I said "I can't wait for the new 911 to arrive !" Next thing I know 4,000 Taleban have added me as a friend !! Being a modest man, when I checked into my hotel on a recent trip, I said to the lady at the registration desk ... "I hope the porn channel in my room is disabled." To which she replied, "No, it's regular porn, you sick bastard.†The FBI have discovered how to weave prayer mats out of plastic explosives ....... Apparently prophets are going through the roof !!! The Red Cross have just knocked at our door and ask if we could help towards the floods in Pakistan I said we would love to, but our hose pipe only reaches the bottom of the garden Quote Share this post Link to post Share on other sites
