OLLIE 26 Report post Posted April 12, 2005 Once again an E30 master cylinder appears to have shat itself. atleast that is what my self diagnosis is. I would like to rebuild it, replace the 2 rubber seals and the spring? (bore??) Can anyone offer me some information or advice on this subject? ....... Quote Share this post Link to post Share on other sites
CaM 0 Report post Posted April 12, 2005 make sure you use a proper hone to clean up the bore..... they corrode (brake fluid draws in moisture like i repel women) they get a bit rough with corrosion and then your new seals will just get all cut up..... I reckon just to be sure, pull it apart before you bother getting a kit, just to see if its worth doing, or getting a new cylinder Quote Share this post Link to post Share on other sites
OLLIE 26 Report post Posted April 12, 2005 yeah i have it (gus's old one) apart and everything appears to be fine except the spring inside looks a bit mangled. what is the rubber bung on the side of the cylinder for? where's the best place to get a cylinder kit from? Quote Share this post Link to post Share on other sites
CaM 0 Report post Posted April 12, 2005 brake and trans (BNT) etc.... i find, in palmy at least, it's cheap as to go to the "one man band" type backstreet shops..... auto brake and clutch in palmy is cheaps as on stuff like this, even pads, shoes, clutches, right up to heavy truck type crap, is really cheap.... especially if yo blah on bullshit about being trade workshop or somethng lol haha, I have no idea what the bung is...pic? Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted April 12, 2005 yeah i didnt do the hone on my old old one and it didnt work...ended up getting new one...the rubber bung is to take fluid from the resevoir ollie loves clutches Quote Share this post Link to post Share on other sites
OLLIE 26 Report post Posted April 12, 2005 the bore seems fine, the spring is in 3 pieces. BNT 2moro Quote Share this post Link to post Share on other sites
Deftones 0 Report post Posted April 12, 2005 (edited) BNT also do full kit new cylinders as well as the recon kits. The recon kit includes the rubbers only. I bought a new slave cylinder, as my old one had shat itself... The bore was corroded as fuk, and a rubber was screwed causing fluid to leak into the bellhousing. Edited April 12, 2005 by Deftones Quote Share this post Link to post Share on other sites
318is 0 Report post Posted April 12, 2005 (edited) My advise is not to shag around with reco'ing such a important part of your clutch system. It will fail, and it will always fail at the most unfortunate time. Suck the fat one and buy a shiney new one man. You won't regret it, and it will be cheaper in the long run. Flick your old one and acquired one on Trademe to some sucker for some cash back or beers If dosh is a prob, PM me and I'll hook you up with trade and 20th month following payment. Edited April 12, 2005 by 318is Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted April 12, 2005 BNT sell brand new slave cylinders for $30, brand new master cylinders for $50, and as CaM said they're a brilliant outfit. $50 is nothing for a whole new master cylinder. The master repair kit by itself is $20 from memory...no decision there really, buy the new one!!! Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted April 12, 2005 do a new one. Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted April 12, 2005 new one. BNT are the shizzel Quote Share this post Link to post Share on other sites
downlow 0 Report post Posted April 13, 2005 yip aggred. BNT word! Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted April 13, 2005 BNT sell brand new slave cylinders for $30, brand new master cylinders for $50, and as CaM said they're a brilliant outfit. $50 is nothing for a whole new master cylinder. The master repair kit by itself is $20 from memory...no decision there really, buy the new one!!! my last quote for a master from BNT was $130....where you getting em at 50? Quote Share this post Link to post Share on other sites
OLLIE 26 Report post Posted April 13, 2005 BNT quoted me $130ish for a new master and $28+gst for seal kit (not including spring) why buy a new one? the only thing to go is the seals or the spring? so if you replace those and do a good hone then it's just as good as new. this will cost me only $10 for spring and seals - from a hydraulic shop. does anyone strongly disagree??!/1?!?!?!?!??!11?1?1 Quote Share this post Link to post Share on other sites
m325i 728 Report post Posted April 13, 2005 (edited) i paid about $130 not long ago @Ollie do you like dumping the clutch? clutch kick mid corner? Edited April 13, 2005 by m325i Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted April 13, 2005 Sorry Ollie The Slave cylinder new is $50, the master repair kit $30, just got my prices all mixed up. Given that the master is $130 (BMW sell it for $180 I recall) it's still not that bad. The repair kits only have the seals and not the springs. Tough decision, i'd just replace the master so you don't have to do it in the future Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted April 13, 2005 ........ anyway its rebuilt.....in tomorrow...onwards and upwards and M325i, why would clutch dumps mid corner be bad for the master? or slave? if that s what your implying? Quote Share this post Link to post Share on other sites
OLLIE 26 Report post Posted April 13, 2005 i paid about $130 not long ago @Ollie do you like dumping the clutch? clutch kick mid corner? Haha occasionaly when the time feels right.... why do you ask? Quote Share this post Link to post Share on other sites
petone 0 Report post Posted April 14, 2005 My master cylinder shat itself a while ago, i only did a quick fix, no hone. Now I think its playin up again so I'll do it properly this time with a hone etc. As for the recon kits, they cost about 25 with BMW club discount however mine was a little different and some of the seals didn't fit. I ended up buying 2 random seals off BNT instead for about 2 bucks each. You don't use half of the seals you get with the kits. Just buy the individual seals. As for new master cylinders the best price i found was $100 from hutt city auto parts. Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted April 14, 2005 My master cylinder shat itself a while ago, i only did a quick fix, no hone. Now I think its playin up again so I'll do it properly this time with a hone etc. As for the recon kits, they cost about 25 with BMW club discount however mine was a little different and some of the seals didn't fit. I ended up buying 2 random seals off BNT instead for about 2 bucks each. You don't use half of the seals you get with the kits. Just buy the individual seals. As for new master cylinders the best price i found was $100 from hutt city auto parts. I should point out that the seals you get from BNT in the repair kits look completely different to the used seals when you compare them together as the used ones will have stretched something chronic, don't just assume that they're incorrect!!! Quote Share this post Link to post Share on other sites
petone 0 Report post Posted April 14, 2005 No trust me, they were completly different. The BNT person agreed with me, there was no way they were going to fit. Quote Share this post Link to post Share on other sites
OLLIE 26 Report post Posted April 14, 2005 well i rebuilt it and it's running well, so far. Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted April 14, 2005 ollie pwns me Quote Share this post Link to post Share on other sites
